Mine idles as a5h said too, revs really high until it warms up.
My car was running really sluggishly (had been since I bought it and no one could find the problem), we changed the plugs and cleaned the throttle body, which mind u, was caked with black sludgy crap and its idled higher and lost its flat spot since then!
It may have made a little bit of a difference when u cleaned the throttle body out..?
https://www.sau.com.au/forums/topic/18212-idle/#findComment-385337
Well I have checked the ecu codes, and disconnected the battery to no avail. The ecu came up with code 55; admittedly it was after i disconnected the battery and drove it for two days with the same problem. I did notice the vacuum hose coming off my aftermarket BOV was slightly cracked, so started wondering if this was the cause of the problems? Any thoughts????
I have also checked the TPS, 0 ohms result, and the AAC valve had continuity.
I remember seeing how to adjust the idle via the ecu, but I cant remember where I saw it?? Anyone know of this????
The only other thing I can think of doing is adjusting the AAC valve screw, but Im worried it will alter the air/fuel mixture to its detriment, even though it only controls the air flow.
Any help greatly appreciated.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-398022
Its supposed to idle high when the engine's cold.
There's a screw on the back of the ECU - you have to remove the ECU to get at it. But its for very fine adjustments.
Adjust the AAC screw, it won't affect the A/F ratio - its only effective at idle, it allows air to bypass the (closed) throttle.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-398589
This is normal to idle at around 1500rpm when cold then to drop around 650-800 is okay anything higher should be checked... They all do this, they are meant to. Its programmed in them to warm the engine and get the oil flowing better on startup cos of the turbo, rather than having to wait for the car to warm itself over a longer time thsi helps it get things rolling.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-403559
That's right. There are a lot of cars that act the same way. It warms the car up faster. You should not give a turbo car heaps when it is cold (any car for that matter). :burnout:
https://www.sau.com.au/forums/topic/18212-idle/#findComment-404578
After much deliberation, I adjusted the screw on the AAC Valve, to no avail. It only dropped a couple of hundred revs. I then decided to pull off the whole air regulator with the AAC Valve on it, to find that the AAC is stuck partially open in its unmounted state, (but still bolted to the air regulator.) I put 12v to it, and it didnt work as it should,(contracting the inner pin), and even after plugging it straight onto the end of the wiring loom, it still did nothing. I figure this is what is causing the high idle. Does anyone agree with my theory??
Thanks in advance.
Just as a matter of interest. my mates manual 33 idles at 1000 rpm cold and drops to around 700-800rpm once warm.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-411892
I did adjust it with plug disconnected, with above results, which is why I pulled it off again. I cleaned it with carby cleaner intially, hence the above problems. It only had a small amount of carbon in there & the throttle body BTW.
Any other thoughts???
https://www.sau.com.au/forums/topic/18212-idle/#findComment-413658
I have since swapped the whole AAC valve assembly with my mates, whose car idles at a respectable 1000rpm cold. This did not change anything at all on my car. I have been told it could be the TPS, even though it measured 0 ohms, the variable resistor may need to be readjusted. Anyone one else done this before on a Series 1 33??
Thanks in advance!!
https://www.sau.com.au/forums/topic/18212-idle/#findComment-430538
Hi Guys,
Hoping you could help with my problem also. I know high idle at start is normal, but can somebody please explain this. Drove home tonight, and once I pulled into the driveway, in idle, the tacho constantly fluctuated between 800 and 600 rpm. just back and forth. Should I be concerned?
Thanks guys
https://www.sau.com.au/forums/topic/18212-idle/#findComment-431234
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
