BOOSTD Posted July 15, 2003 Share Posted July 15, 2003 rich-lean rich-lean. Its is called hunting, and is caused by ur idle up valve taking a to bigger gulp of air which the ecu over compensates for. Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-431653 Share on other sites More sharing options...
Demon Dave Posted July 16, 2003 Share Posted July 16, 2003 Could also be caused by your aircon compressor pump engaging - if you had the AC switched on that is! Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-431701 Share on other sites More sharing options...
Scotty Posted July 16, 2003 Share Posted July 16, 2003 Thanks BoostD and Demon Dave, well the ac was off so suspect it's this Hunting problem. May I ask, is there anything I can do to stop this, or moreso, should I be worried right now? Thanks! Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-432568 Share on other sites More sharing options...
rb25 Posted July 16, 2003 Share Posted July 16, 2003 Scotty - i rekon your AFM is dirty/dodgy. cav - i think you should try and readjust your TPS. I think its done with the motor running, move teh TPS around very slightly. I cant be sure about this tho'. Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-432711 Share on other sites More sharing options...
YEE-HAA Posted September 14, 2003 Share Posted September 14, 2003 I have finally got my car to the mechanic, who said it wasn't the TPS, or the aac valve, but it was the air regulator under the inlet manifold. Mine was stuck fully open and sucking lots of air all the time and needing lots of fuel at the same time too. I have changed it and my first week's normal run showed an instant improvement with a 12.8l/100km around town. A lot better from the high 13's-low 14 l/100 I was getting before. Cold start idling is now at a respectable 1100 rpm and then around 600-800rpm when warm. Also feels like a different car to drive as well. Next thing to do is fit the new fuel pump! Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528058 Share on other sites More sharing options...
Bl4cK32 Posted September 14, 2003 Share Posted September 14, 2003 can u pm me where u took it out of curiosity? Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528129 Share on other sites More sharing options...
crooser Posted September 15, 2003 Share Posted September 15, 2003 BOOSTD i thought 0.50 volts was standard. why 0.43? Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528760 Share on other sites More sharing options...
R33 GIRLY Posted September 15, 2003 Share Posted September 15, 2003 put a valve on the plenum hose (that fixed it for me) Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528772 Share on other sites More sharing options...
BOOSTD Posted September 15, 2003 Share Posted September 15, 2003 which plenum hose? Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528787 Share on other sites More sharing options...
R33 GIRLY Posted September 15, 2003 Share Posted September 15, 2003 the one that runs from the back to the fmic pipe i think, hold on i will go and look (sorry i not up with the proper names but least i know what does what) Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528806 Share on other sites More sharing options...
BOOSTD Posted September 15, 2003 Share Posted September 15, 2003 so the idle up valve doesn't see positive pressure ? I have noticed my car idles better when driving without boostin.......interesting Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528827 Share on other sites More sharing options...
R33 GIRLY Posted September 15, 2003 Share Posted September 15, 2003 hope the pic works this time Link to comment https://www.sau.com.au/forums/topic/18212-idle/page/2/#findComment-528854 Share on other sites More sharing options...
