optimax is gay.. mine don't like optimax sometimes and it has schisms.. Mobil 8000 or Ultimate.
Aw...poor nark has an inferiority complex :D
haha.. yer, right - soon as you tune the SAFC up it will be using *more* petrol.. mine is shocking.. try $50 for 350km :D
What boost it running? So does it have that like TV display/control thingo? they are pretty cool.
An idea for my next cheap car :P but i am not sure whether i want the big boat thing going on. I might just get a little road rocket.
https://www.sau.com.au/forums/topic/18213-aaargh/#findComment-380354
thats what a 1/4 mile is Rob, yup :D
Will be interesting! Where abouts Nark? Calder?
Might come and watch.. it is pretty hard to line up against another car at Calder these days though Ni. We were trying when we got a few SAU guys a while back, and none of could manage to line up against each other - its just too complicated and they don't really cater for it properly :D
https://www.sau.com.au/forums/topic/18213-aaargh/#findComment-380927
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
