Hi guys,
Just getting rid of my Bilsteins from my s2 r33 non turbo, upgrading to coilovers. Product number is F4-B46-1916-H0 if that means anything to anoybody.
Theyre in good condition still work perfectly, never ever had a problem.
I find the ride pretty firm, but nothing harsh as the shocks seem well matched with the springs.
No body roll until you push it. I bought them about 15,000kms old then the dude i bought them off decided to hit a telegraph pole, when i checked them out, they still seemed perfect. I've had them in my car for about 2 and a half years, done less than 20,000k's.
Looking for $400 for all 4 with springs, will considder separating springs and shocks if i get buyers for both. Buyer pays post obviously (from Sydney).
Let me know via PM, I'm keen to get rid of them, don't wanna muck around too much.
I attached the pic of them, rears are the long ones.
Edited by oly124
They're off my series 2 non-turbo r33.
I live in sydney, near hornsby.
I'm happy to sell rears for $200 only If someone wants to buy fronts for the same. I don't really wanna get stuck with one pair of struts as they're a set of 4.
NB. also have a pair of really low front K-mac springs if anyone is interested.
any idea of the rears will fit a series 1 gtst?
x2
how hard were they on the road?
i'm assuming they're not height and damper adjustable??
interested in the full set if you provide pics
The shocks are not overly hard, there is still moderate movement when you hit a rough speed bump or something. I found them to be a good compromise as they are comfortable driving and dont throw you round or anything like that. And no they are not adjustable.
If anyone lives close i would be happy to take them for a drive.
NB. will fit series 1, person i bought them off had an s1.
Edited by oly124
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
