hey does anyone know how long i need to charge my battery before its ready to go back on my r34. i left one of my ceiling lights on and it killed the battery. bought a charger 3.5amp and had battery on charge for 12 hours, pulled it off to give it a buzz and still nothing ?
https://www.sau.com.au/forums/topic/182172-battery-charging/
Then it is a dead parrot.
If you have a multimeter, test the voltage across the battery. Is it over 12 volts? If not keep charging.
Most battery chargers have a LED that indicates if the battery is charged. Mine took about a day to charge, it was down to 2 volts before i charged it. (My car had been sitting there not being driven for 4 weeks.)
    • Quick update team , while I was getting the water pump replaced to got the Red Alpha Cold Air Intakes installed . Sourced from, Just Japanese in Sydney if anyone if looking at them for their RV37. It was a direct fit no issues , it took about 2 hours , with the instructions provided my AMS Performance - Link Below https://www.amsperformance.com/product/ams-performance-infiniti-q50-q60-red-alpha-carbon-fiber-cold-air-intake-kit/
    • You need to jam something inside it to stop it collapsing. A washer, a spacer, a something. Needs to stay up at the fully pumped up height. I still say you can measure centrelines with a collapsed hydro lifter. Whatever max lift is will be max lift regardless of the state of the lifter.
    • Yeah, I've been watching him since the first 4 posts all arrived.
    • Quick update Guys , managed to get the water pump replaced . I first my mechanic went back and forth with Nissan AU (4 weeks) and they weren't much help, at the end they noted something about not supporting imports. So I soured the part myself from Japan. If anyone has similar issue here is the part numbers  Genuine Nissan PUMP ASSY-WATER - 21010-4HK0E Genuine Nissan Gasket - 21014-4HK0A  Cost me about $230 including shipping (I had in within 10 days thanks to Blackhawk in Japan)  They are basically the same as the Red Sport or even the new Zed - here is link to a supplier in US who helped me confirm the parts matched  https://www.z1motorsports.com/water-pump-fan-and-thermostat/nissan/oem-14-20-vr30ddtt-water-pump-p-10167.html You can change it yourself if you like , but I had my local workshop do it , it was about 5 hours of labour.  Cheers  Pac
    • +1 for these guys, they just made me a custom muffler for another car (old Merc V8 not a Skyline) and they are legends to work with and do very nice work at a reasonable price.
