understandably
to increase pressure by at least 2 psi you need to have a fan that will draw more power running it then it would help the engine make....
Exactly what I was trying to tell my mate with an XR8 Ute... he wants to make that exact setup... he's got a motor that will do 25,000RPM on 12V at 2.3A... but I doubt it will be able to push any kind of pressure...
https://www.sau.com.au/forums/topic/182180-turbo-fan/#findComment-3307838
there is one way of increasing pressure in the intake without turbo but it could be a bit tricky
ive seen a guy use a model airplane prop and a biggish motor as a cooling device for his computer
apparently it pushed over 150 cubic feet a minute, but in the process was very very noisy and rather big - over 3inchs in diameter
you would have to make sure nothing fell apart in the intake otherwise it could get nasty
https://www.sau.com.au/forums/topic/182180-turbo-fan/#findComment-3308383
  • 3 weeks later...
it's not just about pressure, it is about airflow. if one of these fans can increase your airflow it may give you a power gain even if it doesn't raise inlet pressure.
But if i understand correctly, airflow is no use unless the air has somewhere to go. Pressure is what is needed in this case as unless extra pressure is applied, you're only ever going to get 2.5L of air/fuel into your engine... no matter how much airflow you have. all this would mean is that it might get there quicker... The main concept behind turbocharging is that you effectively get more air/fuel into the same size engine, producing the power of a larger engine without the weight.
Anyway, a turbocharger can spin at speeds of up to 180,000 RPM, good luck finding an electric motor that can do that sort of speeds *and* apply 5-7PSI of pressure *and* not draw a million Amps!
Just my 2c.
https://www.sau.com.au/forums/topic/182180-turbo-fan/#findComment-3348718
i'm not sure of the exact physics of it, but in a turbo car 16psi of pressure from a large turbo makes much more power than 16psi from a smaller turbo...
i dunno how efficiency ranges and heat etc... come into
hit the nail on the head.
Pressure is just a type of restriction, air FLOW is what your chasing.
just think of it this way if you turn on a hose you get wet, you turn on a fire hose you get blown away. Same pressure, just more flow hence more power.
dont waste your time with electric fans, i remember reading some article where a guy spent alot of money trying to set one up and he ended up getting around 5psi, but the electric blower was huge, and it was very noisy.
If you want forced induction, turbo or supercharge it
https://www.sau.com.au/forums/topic/182180-turbo-fan/#findComment-3358161
  • 1 month later...
You have got to be kidding. A fan. Getting the air there faster wont do much...........at all. What you want is more air packed into the same volume going into the engine, then perhaps some sort way of getting it in faster.
If this is for an r32, an RB20det wont cost you much and there is enough of them out there. I suggest you get one, then worry about how much you can get through those pipes.
https://www.sau.com.au/forums/topic/182180-turbo-fan/#findComment-3434540
damn when i saw the title i thought someone put a turbofan on a skyline. (the engines on 737s etc)
the idea is quite silly though. the power required to drive a compressor for a couple psi would be in the order of kW. you probably could get a motor that powerful but it'd be a huge waste of space and power. you would need another alternator to provide that power.
to think of doing this with a 12v @ 2.3A (roughly 25W) motor is absurd. whoever that guy is must have no idea about engineering at all haha!
https://www.sau.com.au/forums/topic/182180-turbo-fan/#findComment-3434648
  • 3 weeks later...
if you go on ebay and search electric turbo.. you will find some for sale...
or www.force-flow.com.au
best bet is to go force flow and not some cheap china product...
it would be good to see someone experiment and see what power results they get..
p.s: they also have twin-turbo... might wana try that
Edited by J3TR33
https://www.sau.com.au/forums/topic/182180-turbo-fan/#findComment-3475150
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
