pump could be on its way out.
Does the gauge consistently read like that everytime you drive or does it fluctuate or jump around. Sometimes a faulty sender unit can cause that misconception...however i havent really seen one yet, only heard.
I would say its a faulty gauge/sender, mine does the same thing, 8bar oil pressure when cold, 2-4bar depending on revs when warm, on idle normally around 2bar but will sometimes drop right down to 0 and stay there for a while, sometimes if you let it idle while the oil pressure gauge is just above 0 it will all of a sudden jump back up to around 2bar and start working fine, some days it is perfect, some days it is fauly as hell, my old r32 gtst done the exact same thing! Very common problem.
If your concerned about it hook up a decent aftermarket oil pressure gauge and see what the readings are.
The gauge in my 32 is all over the place, as long as that warning light doesnt come on then you can relax
My gauge will read close to zero while my aftermarket gauge reads a steady 1bar at idle when warm
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
