Are you from America? How can you call a Stagea a "small car" :P
Anyway, you also mentioned looking for a Stagea engine..... unless I am mistaken they have an rb25det just like an r33 gts-t? What is the difference?
sorry my post is a bit confusing. i meant that the gts4 is heavy for a small car.
as someone else said the sumps etc are different between 2 and 4 wd 25's
Ah i have no doubt that within the 1st month my gearbox will be scattered all over the road somewhere!
What the use of building up a car if you dont break something along the way?
Haha you should be fine if you are only pushign round 260-280kw
The GTS4 gearboxes are strong as :) unlike the standard GTS-t ones
They are similar strength to the GTR but different ratios apparently, but yeah RIPS and a few others over here in NZ regularly run the GTS4 gearboxes with no trouble,
It's basically 3rd gear that you have to be easy on, but that goes for the GTR boxes as well, they tend to strip them if you don't change gently down the strip :S
that being said, mines still fine :) for now...although it's off the road for 6 months for "modifications"...
It might not be a 'real' gtr, but I like the fact that I can park it somewhere and not have to sit there watching it all the time, afraid of it getting pinched, keyed, etc. No-one cares about a bunky.
It would be interesting to get a gtr and gts4 on a weighbridge, for a start I have seen wildly varying reports on r32 gtr weights across the production run, the motor in the gts4 might be lighter, but the gtr has aluminium fenders and bonnet.. could be even closer than that.
I probably woudln't have bought a stock gts4, was looking at rb25 r32 gtst's. This one popped up cheap, but looked like my avatar. Spent the first two months of ownership in the panel shop getting rebuilt. Although it did come with gtr brakes, suspension, drivetrain. Gts4 diff ratios. Lots of fun. Stock motor stock turbos with 221rwkw.. so far.
james.
Then come and have a look at my passenger door. It is the same door that was fixed (from a keying incident) before I bought it.
I don't think it matters a rat's what the car is - some people just have no respect for other people's property, and will run a key along the door simply for the sake of it.
for starters the GTS4 has a GTSt's heavy bonnet, guards and boot. Swap em for GTR items and there's a good enough weight saving. The diff is pretty pisspoor compared to a GTR. Viscous LSD's suck. Good diff ratio's though... unless you own an auto GTS4, in which case you'd have the worst diff ratio of the field.
Its a GTSt that was made for going to the snow and pulling your boat around. Its not the next step up from a GTSt to a GTR.
I own one because they're so much fun to mod... you get to play with ATTESA, ABS, HICAS (if you don't rip it out) and still run a single turbo that's very daily drivable. The ECU is virtually identical to a GTSt, so modding that is piss easy (try doin that on a stagea). You can get parts from GTRs (suspension, drivetrain) and GTSt's (turbo's, bodykits etc).
To me that's exactly what I like in a skyline... "tinkerability".
they are just a 4wd gtst, and anyone who calls it a 'mini godzilla' is a knob.
What a stupid thing to say buddy. How is a GTS4 NOT a mini godzilla. It clealry is just with a smaller engine and one less turbo. It has ATTESSA it's just got less power. Keeping that in mind my GTS4 is running about 300hp at the moment and will destroy a tool in a V8 and quite a few Skylines etc. and I have great handling, and shit is it fun in the wet. For those who dont want to outlay the extra $$ for a GTR a GTS4 is a great option. And it is a Mini Godzilla. No-ones claiming it is a Godzilla. PLUS if you purchase the GTS4 then put in say and RB30DET it's cheaper than a GTR, It's got better diff gears and it'l go quicker than a GTR. You're the nob stooge.
Take it easy all.
Edited by WhatBrake
y dont u not waste all that money on it and buy a gtr like a normal person
If this is directed at me then i answer you with a "why"?
I could easily just drop an RB25 or an RB26 in and be done with it but that too easy.
THe RB20 is a HIGHLY underrated unit. I love em to death and refuse to trade up. Maybe one day.
because its got all the weight of a GTR and none of the power. The worst of both worlds! GTR is about performance, and the GTS-4 doesn't have much of that - power, brakes, diff, track... GTS-4 was a commuter with awd, that's all. The GTS-T is a better performer than the GTS-4, maybe its a more worthy contender for the min-GTR title???
its not a mini GTR even if you add the front bar and rear spoiler :thumbsup:, its still just a heavier, slower GTS-T.
Edited by hrd-hr30
Actually its heavier than the GTR as it has the non lightweight fenders and bonnet of the GTSt, and the heavy drivetrain/chassis of the GTR :P
It was sold quite literally as the skyline you'd buy so you wouldn't get bogged in the snow, or if you wanted a GTSt that could tow a boat/jetski... in the R32 the power to weight wasn't good enough that they had to include a turbo, but in conswquent models they took that away and made them N/A.
That said, once you start modding them and replce the GTSt parts with GTR parts they can be a bit of fun.
As an aside, they used to make AWD diesel mirages for use in snowy areas. No one liked them much until one smart lad decided to put mitsubishi cyborg parts in it and made a pocket rocket. The point I'm trying to make is that one man's trash is another man's treasure. Try to keep an open mind.
hi from kiwiland
my not so baby godzilla is running a rb30det with a gtr box and it probably more fun than a stock gtr :D .
if you want to put a 25det in you can use an adapter plate between the sump and block with the rwd blocks.awd blocks are wider at the bottom to accommodate the gts4/gtr sumps.
the gts4 boxs r ok but the gtr boxes r heavier ?stronger with a very tall gears(im getting about 65km out of 1st :) )
the best post is the "r33 rb30 conversion" which covers most the 4wd mods needed for the rb30det which will be the same for the rb25det but if you're gonna put an rb25 in you might as well put an rb30 in as it gives you a bigger bang for your bucks.
p.s im pretty sure R.I.P.S uses an r33 gtr box in his 10 gts4 rb30det
l8ta
1.) stop calling a GTR a GODZILLA
2.) stop calling anything a BABY GODZILLA
3.) RIPS "now" uses a GTR box in the 10sec GTS4 but it had run a few 10's with the stock GTS4 box.
obviously it broke, just like the GTR one will eventually break.
I too had a 4 door GTS4.
piss poor performance with the RB20.
only good things was the launch. once you are moving, it's a slow heavy gutless vehicle.
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
