'88 Silvia K's Ca18det
CA18det
White over Gold 2 tone
10,500 ONO
MODS:
S15 t28bb turbo
Metal head gasket
Nismo 600CC injectors
Heavy duty clutch
JunB.L. 3 1/2 inch turbo back exhaust
High flow Cat
Microtech ECU (big dollars$$$)
HYBRID FMIC - stainless piping
Turbosmart BOV
bosch 984 fuel pump
Greddy Oil catch can
Autometre boost gauge
High performance odyesse battery
Wiring loom replaced
ECV with inbuilt TT
All major seals replaced, including cranks seals and sump gaskets
NGK Platinum Spark plugs
D2 adjustable castor rods
D2Lower castor arm bar
D2Rear camber arm bar
zenith alloy Subframe bushes
Alluminium steering spacer
BSM green stuff brakes
Autotechnica steering wheel
POD
New alternator
Cobra alarm(central locking-keyless entry,imobilser)
Front Strut Brace
Fire extinguisher
New radiator(thicker than stock)
cusco springs in rear
Custom cold air intake
6x9 JBL rears
Alpine fronts
Pioneer head unit
Sunroof
Serviced regularly
Black driftteks with chrome lip(will negotiate on price with buyer)
Extremely good rubber on wheels
Has slight damage on passanger rear 1/4, was due to a car park incident
And slight paint damage on front bumper - nothing major
PICS UP 2MORROW
Reason for sale: Working in the mines, no need for such a high performance car, when im only back for 1/4 weeks per month
Contact Details are
Nathan Bolton
0416 744 499 - Call or text, as i dont check the forums often. Test drives welcome, but no tyre kickers
Located in Mount Osmond
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
