yeah, i went to the cruise last night, have to say it was the biggest i have ever seen. Timmmayyy, did you see that r31 in bunnings that smoked it up good and proper??? THAT was GOLD, pure GOLD, although i don't know if he really needed people to lift up his guards lol
