Front passage seats, 1 ciggy burn. $80.00ea
RB20DET Exhaust manifold and cover $20.00
RB20DET Dump Pipe $10.00
Passage orignal speaker covers, faded. $10.00 *they say skyline on them*
Stock Blow Off Valve $10.00
Stock crossover pipe $15.00
Stock turbo cover $10.00
Stock Oil and water lines for turbo $20.00
Passage front bumper $20.00
Drift cannon 2.5in, 4 out. i'll even polish it up nice with my buffer and some autosol. come up like new. $30.00 Been on the car for 3000kms
Autobarn drift wing. $50.00 (new. cost $320 with receipt)
CIGWELD TRANSARC 141VRD
Pulse Lift Tig operation
Compact lightwight and portable
Single index control knob
Outstanding DC Welding Charicacteristics
Hevy Duty 70% Duty Cycle
Easy to use digital display
EMC compliant
Cost $1200 new i found on the net.
Selling for $300.00 or swap for somthing in my interest. Comes with a box of stainless rods and fero's.
Perfect cond, hardly used, selling cause im upgrading.
Edited by Clintarous
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
