2 x R32 GTR wheels for sale.
Ideal for drag wheels on a GTS-T or to replace damaged wheels on an R32 GTR. They have plenty of tread on them.
$600 ono.
1 x RB25DET Spark plug cover $80
(Plastic plate that covers spark plugs and coil packs - good cond)
1 x Set of R33 GTST Factory Springs - Good Condition $40
1 x R33 GTS-T Factory front pipe and dump pipe $50
1 x Set of S14 200SX Factory Springs - Good condition $40
1 x S14 200sx Factory Airbox with as new K & N Panel filter $80
1 x Brand new wurth Fuel regulator - factory type
(Suitable for R33 GTS-T) - Offers
Located in Sydney
Nick
https://www.sau.com.au/forums/topic/18228-r32-gtr-wheels-other-misc-parts/
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
