  • Replies 213
14 Members: Russman, sneekee, acsplit, TurboX, Stu-RS, Swink33, NYLATE, rexdan, Budge, GTS-T_Sedan, deafwish, tjandriesen, Roy, sammus
Looks like we're all waiting on results!
Nope...pics! :P
Results will be Handbags, Scotchfinger, Snowcone and Daz in no particular order for the top 4. So with that out of the way...where are the pics that will make ppl blush :)
Hey Groovers,
DECA was totally awesome!! You guys rock! The best fun you can have with ya clothes on i reckon. It was my first time down to DECA and hopefully not the last for me and the mrs. The drive home to the Central Coast NSW (about an hour and a bit north of Sydney) sucked arse, but I'll certainly make the trek down again if i get a spot at the next one. Without a doubt one of the best weekends I've had in a long time. See you all at the next one!!
Cheers again guys
Cant wait to check the results and pics!
Ok here's a strange question:
Over the weekend i was talking to someone about highflowing injectors - pretty sure it was at the cabins but not 100% sure. Who was it? I wouldnt mind talking to the highflowing guy :P
Nope...pics! :P
Personally I don't care who won so much as to see how my times stacked up...
Sarah and I had awesome day..cbf'd staying up for the weekend but maybe next time.
Thanks to all the peeps that make it happen.
Got some decent pics that I handpicked out from lot that we took..uploading now..
here's one vid i put together of myself, snowy, ferni and john picture in picture for some shits and giggles!
deca 4-in-1 first course
Thats very cool mate!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
