  • Replies 213
What a Blast!!
DECA is a fantastic way to spend the weekend. Spesh thanks goes out to all who had a hand in organising the event and doing the course testing (you all know who you are). Adz and Dee, love your work, we both look forward to shacking up with you two again :)
Fish bowls, Taco's, burnt oil and tyres, bin rides, broken bits, tits out, and Mav's piss holes in the snow eyes, are things that come to mind after the weekend. Some ace photos there too, but also some incriminating ones too…...
    • Hell yeah. Glad to see it’s closer to the road.
    • Thanks Brad Sheriff. I think he single handedly made the price of NEO heads rocket to the stratosphere.
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
