Yeah, not happy Jan. Took it for a flog tonight, all was well then one of the clamps popped off and had to limp it back home. Still have a bit of cutting of my front bar to do also, not heaps, just a touch here and there. Just really can't be effed anymore today, been working on it since 11 :)
  • Replies 241
Posted Images
yea lol. passenger front quarter is f*kd. need a new one. head light was smashed, front bar is fine but scratched up bad, lower control arm bent like banana. I was doin about 100 when it aquaplained....spun instantly 2 or 3 times, there was nothing i could do in the time it happened...just glad that was the only damage and no one was injured.
Looks like I wont make it either unless I can figure out my problems, Went for a cruise last night and all was fine for most of it, But as I left Ingle Farm I couldn't let my rpm go over 2000 otherwise the engine would stall. I have looked for loose hoses but can't see anything may have something to do with the injectors or the turbo as once it starts to boost that is when it splutters and dies!!
Any help would be great
I live in the northern suburbs if anyone wants to come have a look just pm me :)
sorry to hear Ryan i saw you WTB post and though ah no
outcaast check all hoses coming off the plenum and IC piping sounds like air leak im not sure where from though
when i first bought my car it was in for repairs one day and then when i picked it up within 5 mins a hose poped off and did same thing yours is doing
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
