dont use a microguess, only poor rotor owners use them
and make sure u get a WRITTEN quote from predator, or expect to pay 3x the amount they originally quoted u, im dead serious
P.S have fun lighten up 3rd on the fly when she's done :)
lol only poor rotor owners like pac performance? on their 6 seconds drag car? u have no idea do u lol
microtech would be fine for you car but im not sure if it allows u to keep all your electronic comforts such as air con. as for tuning its fine mate.
nice choice of turbo
I made 303rwkw at 18psi with the same turbo (with the .84 rear) tuned by predator
In theory it should be a good set up....spools up nicely but yet to fell the full effect, but the less said about that in public the better
Any dyno graphs?
I am using this turbo on my RB30DET build and wouldn't mind comparing it to an rb25det.
My engine will have the following parts: GReddy plenum, q45 throttle body, 550cc SARD inj, Tomei Poncams, Extensive Head Porting, Tomei Valve springs, High mount ext manifold (Extreme Turbo Manifolds), Forged internals, GTR race bearings, ATI balancer, etc.....
All tuned via a Wolf3D V500
I was hoping for anything between 270-300rwkw; but after reading your post i am looking at about 320-340rwkw@20psi :)
Any dyno graphs?
I will get it and scan it for you mate
well its not looking good for the weekend :pwned: car is at Predator now getting exhaust done, but I am waiting on an intake pipe to arrive. I am flying to sydney tomorrow arvo and wont be back till 7:30 Friday night, and I need to get the pipe to the shop so they can fit it up. So I guess I'll be seeing you guys next weekend if anything is happening, but im pretty sure I'll be so happy about having the car back on the road that i'll be driving it down the driveway to check the mail I miss it that much, hahahaha
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
