Yes folks that's right, I'm leaving on holiday and that means no whoring from yours truly:(
I'm leaving for the UK today (14th of June) and will be away 1 month:D
I will try and get on the net at least once a week so you can still PM me:D
Hope you all have fun while I'm away and don't miss my whoring too much;)
Bye
Paul
  • Replies 71
Seeya pwptpf.
we will miss you * sniff *
NAAAAHH just kidding, prank will be happy cos his server bill will drop by 1/2.
Anyway , have fun and remember that y,all come back now..
Cheers
Ken
Originally posted by Pva_Glue
Have Great fun and do not any catch skanky shela from England... and STD and SARS, what ever they have....
They have mad cow disease :P
Cya Paul make sure u drop me lotsa msgs :D
I'll try n keep the whoring seat warm seeing ive got no distractions now haha
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
