hey guys i have the following.
r31 skyine
with kings sprins low
21mm rear sway bar
strut brace
r33gtst front brakes
nolerthan bushes
adj camb caster hats.
17x7 rims
was just wondering what i should set the front end to for winton race way to get the best handerling
https://www.sau.com.au/forums/topic/182337-what-settings-to-use/
r31 skyine
21mm rear sway bar
strut brace
nolerthan bushes
17x7 rims
if Winton is a slow and tight circuit as I understand it is, run as much negative camber on the front as you can. you could benefit from getting adjustable shocks or coilovers. if you are understeering increase rear stiffness and/or soften the front. if you are oversteering soften the rear and/or increase front stiffness.
is the strut brace on the front? if you find you are understeering it will help to remove the front strut brace.
cheers
