Soon i am expecting a large shipment of the following items,
please let me know if you want any of the following so i can make sure its set aside.
BOV $40
Boost controllers manual and electronic ranging from $30-225
Fuel pressure regulators with Guages $50
More items such as Waste gates and such are comming but prices have not been worked out yet
please leave me a msg, and ill take ur details and get it organised.
these items are not for sale YET, talking to admin about setting up an advertizers account to sell these soon.
ive used a couple of these to test out, not a problem, pulled it apart, decent spring, adjustment works perfect, cant find any problems with it.
Yeah, I'm guessing these are the copy HKS/Greddy BOVs that you see on ebay alot.
...but considering the simplicity of a BOV, i wonder how these perform compared to the original?
they might be the go (meaning to sound positive here) :)
They are made in china, i have tested them, i would never buy a turbo from them, i would include a warrenty . im located on the goldcoast / brisbane
bov are pretty simple i checked the spring and it seems quite decent, the FPR, holds pretty high pressure, i tested it out on a bench and kept it going at high pressure for a couple of hours works flawlessly.
oh and yes the purple one is a plum back for sure after a second look
Edited by ragex
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
