Thanx !!
If all goes well... I'll post a msg!! Even if it didn't I'll let you all know!!
Matt, thanx for telling me about the MJR!
MJR were really nice over the phone and really helpful!
Well the ticket didn't get waved......
so I'm making sure nobody(well... the police...) says anything about my tail light anymore.
thanx everyone for all your help!
Thanx Jesse for coming with me!
How does that work? You proved to them that it wasn't painted and you still have to pay it? :wub: That's total BS they can't fking book you on something that is a factory standard...
I really hope you manage to have better luck if you take it to court or sumsing :wub:
Since this is an easy case to defend in court yourself, and it would cost nothing except some time, ask to discuss the matter with a senior officer at the station this guy works at, ask for some intelligent intervention and state that you will take it to court if necessary.
I'm pretty certain, if the evidence is presented to one of the older heads that they will see sense in not prosecuting.
Judges hate to see matters that are just petty, pointless and wrong and will give the coppers a dressing down if they do present this case.
thanx everyone....
I doubt I will take it to court.... maybe go see the head of that station to talk to him about it.
I don`t have the time (got work everyday) to get summoned to court on the day they ask me to come.
I do wish most police are not this dumb.
I hope you dont pay... this is a perfect example of how we should stand up and fight against bullshit tickets....
my latest one was for driving with headlights on during the day (highbeams too) but still
I know what you mean...
but since the police man told me to prove it to him and I did... (with a bad answer from him)
all I can do now is to bring it to head of that station and tell him.
I dont have time to go to court now.... work work and more work.
I will try as much as I can but got doubts its going anywhere now...
talk to a compliance workshop that complies R32 skylines. They have ADR clearance/testing data for both coupe and sedan tail lights (sedans are variants on the original docs). This should show factory specification, translucency, colouration and reflectivity. Most of em won't give the info away easily (because they spent hundreds tabulating it, and you could be a competitor) but be nice and they might just give you a copy of that page out of the 100+ page ADR evidence book.
head of the police dont have much time since the indy's on in the coast in 2 weeks. Cops are all busy doing whateva they think they are doing.
Courts out of my mind at the moment. My work is buzzzzyyyyyy! Its summer time and all dogs need clippings!!!
I think I will go pay it soon.... or I'll get another fine for not paying.
*sigh*
Yeap definantly don't pay.
Also from everything I've read regarding mods and what is and isn't allowed I beleive that it doesn't matter as long as they remain clearly visable from a specified distance(can't remember the exact distance now) and obviously remained the same colour. I have my front and side indicators covered in nightshade. They are still clearly visable. I have never had a problem and even passed a proper RWC with it.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
