Thanx !!
If all goes well... I'll post a msg!! Even if it didn't I'll let you all know!!
Matt, thanx for telling me about the MJR!
MJR were really nice over the phone and really helpful!
Well the ticket didn't get waved......
so I'm making sure nobody(well... the police...) says anything about my tail light anymore.
thanx everyone for all your help!
Thanx Jesse for coming with me!
How does that work? You proved to them that it wasn't painted and you still have to pay it? :wub: That's total BS they can't fking book you on something that is a factory standard...
I really hope you manage to have better luck if you take it to court or sumsing :wub:
Since this is an easy case to defend in court yourself, and it would cost nothing except some time, ask to discuss the matter with a senior officer at the station this guy works at, ask for some intelligent intervention and state that you will take it to court if necessary.
I'm pretty certain, if the evidence is presented to one of the older heads that they will see sense in not prosecuting.
Judges hate to see matters that are just petty, pointless and wrong and will give the coppers a dressing down if they do present this case.
thanx everyone....
I doubt I will take it to court.... maybe go see the head of that station to talk to him about it.
I don`t have the time (got work everyday) to get summoned to court on the day they ask me to come.
I do wish most police are not this dumb.
I hope you dont pay... this is a perfect example of how we should stand up and fight against bullshit tickets....
my latest one was for driving with headlights on during the day (highbeams too) but still
I know what you mean...
but since the police man told me to prove it to him and I did... (with a bad answer from him)
all I can do now is to bring it to head of that station and tell him.
I dont have time to go to court now.... work work and more work.
I will try as much as I can but got doubts its going anywhere now...
talk to a compliance workshop that complies R32 skylines. They have ADR clearance/testing data for both coupe and sedan tail lights (sedans are variants on the original docs). This should show factory specification, translucency, colouration and reflectivity. Most of em won't give the info away easily (because they spent hundreds tabulating it, and you could be a competitor) but be nice and they might just give you a copy of that page out of the 100+ page ADR evidence book.
head of the police dont have much time since the indy's on in the coast in 2 weeks. Cops are all busy doing whateva they think they are doing.
Courts out of my mind at the moment. My work is buzzzzyyyyyy! Its summer time and all dogs need clippings!!!
I think I will go pay it soon.... or I'll get another fine for not paying.
*sigh*
Yeap definantly don't pay.
Also from everything I've read regarding mods and what is and isn't allowed I beleive that it doesn't matter as long as they remain clearly visable from a specified distance(can't remember the exact distance now) and obviously remained the same colour. I have my front and side indicators covered in nightshade. They are still clearly visable. I have never had a problem and even passed a proper RWC with it.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
