hey, i have just picked up a 33 ser 2 gts-t. i have no reverse lights, i checked the globes and these are fine. i checked all my fuses and these are all fine.
it has a short shift kit installed (unsure of which brand) does this have any impact on the reverse sensor in the gearbox?? has anyone had to replace the reverse sensor if this is my problem
any help would be appreciated.
thanks Brad
https://www.sau.com.au/forums/topic/182413-no-reverse-lights/
hey man, my mate has an series 2 gts-t with the same prob. his reverse globes are fine, but when its in reverse the lights flash on and off....he worked it out to be a problem with the gearstick or whatever sensor controls the lights...when he's reversing if he holds the gear stick forward just a tiny bit the lights go on, but if he lets it sit right down where it does naturally they go off....sounds similar to yours...
if you work out how to fix it post back here and i'll let him know ;)
  • 1 month later...
I have the exact same problem with my R32 GTS-T. Did a search and found this thread.
I found that if I hold the gear firmly into reverse - the lights come on.
If I let it sit in reverse as normal - they dont come on.
Did anyone end up finding a solution?
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
