Relatively simple question, to which I fear there is not simple answer.
Anyway I have an R32 GT-R. Usual bullshit mods including pod filters & an oil cooler. Anyway I want to get cold air to the filters & have pretty much run out of room. My questions are two fold.
1. Does the R33 CAI fit on the 32's?
2. Has anyone managed to fabricate themselves something workable without hacking holes in the bumper etc.
Edited by djr81
https://www.sau.com.au/forums/topic/182445-cold-air-induction-for-r32-gt-rs/
Maybe u will have to bite the bullet and cut a hole or two under the air filters, and feed air up from the passenger side of the bumper.
This works pretty good on gtst's because there is room when u fit a front mount to run a pipe of some sort up to the pod.
It probably wont help you but i think the gtst standard air box gets its "cold" air from a spot that will actually be cold. Failing that ill probably cut a hole and mod the bottom of the airbox so it can feed directly to the bottom of the panel, and not so much tru the snorkel thing.
gl
gl
I can't use the area under the filters because the oil cooler is in there. It dumps plenty of heat. The most of the other areas in the front of the car are plugged full of intercooler, oil cooler, air conditioner heat exchanger, radiator, power steering radiator....
yeah I have the same problem and no easy answer. about the only one I can think of is remove headlight and have headlight duct. I have the same problem. big oil cooler in passenger side duct means no chance of getting air from there.
Baron, if I asked nicely could you see if your 33 CAI fits onto the top of the radiator in the 32?
Edited by djr81
I still use the airbox, I was going to cut a hole through bottom, and get some flexy pipe shit, and put 1 end into the airbox, and the other near the big hole in the front bar (to get away from the oil cooler)
I can't use the standard airbox - the AFM's won't fit.
Even then I can't see a spot for any flex piping as there aren't any spots left other than over the top of the bumper. I really don't want to hack holes in the thing.
perhaps move the bovs, from the drivers side and put the oil cooler there. bovs could find a new home in the engine bay perhaps.
or remove the ac(but keep the heater) and u might be able to get away with the oil cooler between the radiator and intercooler.
ac is overrated ;)
what oil cooler do you have? I have the trust one, and it sits a fair way back. I havn't measured for piping yet, but from a glance it looked like it would fit. but if you could fit a pipe through, i'd imagine that it would make a diference to your air temps even with pods.
Edited by sav man
HKS.
There may be some room to the centre of the blanking plate.
yeah no worries. actually I need to update my profile sort of. my silver 33 GTR was stolen, but I have another one which was just loaded onto a ship today. will be here in 2 weeks. I'll check then.
I got a hold of a stock airbox for mine to get rid of the pods. I'm switching to an apexi pfc with Z32 AFM's. Bolt holes are different but all I did was mark out new bolt holes, drilled em out and fitted longer bolts with locknuts on the back.
Just have to cut new intake pipes to turbos now when I get back.
Well that is great, but how do you get cold air to the airbox?
.............I'll get back to you on that one!!!
Seriously, my oil cooler is on lhs now, I used to have a smaller one on the rhs, in front of recirc valves(pipes removed). So I was going to open up the front of the box, duct in from below headlight, and divert some of the intake air from the lh lower intake(split it from oil cooler).
Have I lost anyone???
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
