well with the impending sale of my R32 (yes, watch out for those interested in a worked R32 gtst auto!) i have for sale a few items that are taking up space in my garage. all items have pictures which are at the bottom:
V35 350GT wheels
- stud pattern is 5*114.3 (same an R32/R33/R34)
- fronts: 17*7.5 +30 with 225/50/17
- rears: 17*8 +33 with 235/50/17
- came off my V35 350GT when i bought it
- nissan centre caps
- NO gutter rash, scratches, or anything. they are in absolutely immaculate ondition - see for yourself
- 90% tread nankang tyres, completely roadworthy
price: SOLD
AFM from an rb20det
- this is a working AFM from an rb20
- will work on any rb20 or series 1 rb25
price: SOLD
AAC valve from an rb20det
- this is a working AAC valve from an rb20det
price: $20
Universal automatic shifter
- this was used on my R32 GTSt automatic for about 1-2 years
- GREDDY racing performance
- looks great, makes the interior look a million bucks!
price: SOLD
Universal hand brake handle cover
- silver
- unused
- looks bling ;)
price: $15
standard R32 side idicators + globes
- 2 * standard SIDE indicators off my R32 gtst
- orange with globes
price: SOLD
Justjap catch can
- has a few scratches and the rubber tubing (oil level indicator) has copped a bit of engine bay heat making it discoloured a bit
- silver
- filled with stockings and steel wool
- has removable top and bottom and plug to drain it if you need to
- looks great in any engine bay (i only had it as a bit of bling)
- comes with about 1m of hosing
price: $30
Beltronics laser detector
- Beltronice vector 945 radar detector
- these are >$500 new
- comes with car adaptor - 2 wires to be spliced in +12 and ground
- for more info: http://alatest.co.uk/apps/reviews/533535/-...Laser+Detector/
- note: these are legal to buy / sell in any australian state, and in some australian states are legal to use (please check your respective state yourself)
price: $90 + postage
all items are located in New Farm, Brisbane.
I am willing to ship small items at an extra expense but for large items like the wheels pickup is the only option
images for all items are below
to contact me, send a PM or reply here - i usually check the forums daily.
thanks,
Warren
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/182464-fs-r32-r33-v35-and-universal-parts/
Hey Waz will that handbrake cover fit an R33
its a universal cover so yes
i never fitted it so its brand new
you need to remove your old cover and then this slides over the top of the core of the handbrake.
let me know if you're interested
cheers,
Warren
EDIT:
for some stupid reason i cannot find the beltronics car charger and maual, they are put together somewhere! argh!
i will have to hold off on the sale of it until i can find them
Warren
EDIT#2:
ok so i found the connector. it doesn't run off a battery it runs off the +12V source continuously, and it had been previously connected by being spliced into 12V from behind the dash
as a result, it doesn't have a cigarette lighter adaptor, rather a "+12V" and a "ground" wire which needs to be connected
also i can't find the maual
as a result of this, i've dropped the price of the beltronic unit to $90 plus postage
this is an absolute bargain for whoever gets in first..
cheers,
Warren
wow that is cheap :)
seeing as i'll never use it and i would rather someone actually get to make some use of it i will let you have it for $20 but that's a once off special for you only.. :laugh:
haha looks like the exact same one i have.. prob with mine is its leaking. is urs leaking..?
i didn't have any leaks. when i sealed it up i used thread tape on the nut and inlet/outlet, and it came with rubber seals for the top/bottom. i put a bit of water into it and inverted it a few times - never had any leaks
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
