While on the topic just a quick question because i can't be bothered searching through 100 posts. You can't run an RB20 remapped ECU on an RB25 Series 2 because of the internal ignitor, correct???
Hm... ive never heard of this problem... keen to hear more also.
Pretty much what i remember reading a little while ago is because series 1 has an external ignitor for the coil packs and series 2 doesn't, a remapped RB20 ECU wont run on a series 2 unless you run an external ignitor.
Hmmm i guess i might just do some searching.
Another guy in another thread posted that, r32 ecu was straight plug in.. Only concer is no VCT support..
quote:
no probs what so ever, plugs straight in, however the 20 ecu cannot run the VCT, was no real issue for me as with the remap done, timing changed, boost raised it still has bucket loads of torque down low anyway!
Getting full boost at 2500 rpm, makes 215 rwkw on 0.9 bar with stock turbo. Drives like a dream, smooth clean power with awesome responce!
Hmmm, the reason i asked about the RB20 ECU on a series II is because one of my mates is a tuner and has a spare RB20 ECU that he could put an RB25 map on and tune it for me. At the moment my car is hitting boost cut/ airflow cut (whatever the hell you want to call it) at 4000rpm on 1 bar of boost on my HKS turbo.
I have 2 options that are possible to do at the moment:
1) Modify a standard actuator to fit the HKS turbo instead of the HKS adjustable actuator and run less boost to avoid the boost cut.
2) Remapped RB20 ECU to get rid of the boost cut and be able to tune it.
Now i know that a full ECU replacement is the best choice, and i will be doing that in the future, just dont have the funds at the moment so im looking at only the 2 above solutions.
So yeah thats my problem at the moment, if i can get the RB20 ECU to run on the series II its going to solve the boost cut problem, because at the moment its giving me the sh*ts.
I didn't know nistune could do the R33 stuff yet.... hmm might have to chat to Matt...
We use daughterboards and real time emulation same as we have on the RB20's for a couple of years now :)
Edited by Dr_Drift
i just heard that they are testing.. it was on their site. They will need someone to test it for them lol
We use daughterboards and real time emulation same as we have on the RB20's for a couple of years now :thumbsup:
I think if you remove the kick panel and lie it on the floor, it won't be standed anymore.
ROFL....i kill me !!! >_<
:laughing-smiley-014: the lame/funny approach to being a spelling nazi :thumbsup:
if your in sydney, i've heard hills motorsport does remaps for r33 gtst's for $350
Edited by into oblivion
These are the simple plug in chip upgrades, and to the best of my knowledge CANNOT be tuned in real time, and also require purchase of a new SINGLE USE CHIP every time you want a new map loaded...
The method we are using is converting the R33 to run a single 27C256 eprom, which can be re-used, as well as tuned in real time with full map tracing etc etc... Hence, the initial $$ are a bit higher, but the end results are WELL worth it.
hehe yea the $$ is scarin me a little.. But i might be a guinee pig and try it out..
so when did you say you are coming to sydney?
Also you got any dyno figures sam? just to see what a similar rb25 with basic mods can acheive..
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
