Hey everyone,
I'm having a bit of trouble with my car. I give you the details then say what i have done. If you can help me it would be much appreciated.
OK, i have a skyline r33 gts-t 1996 series 2. It is pretty much stock engine wise. stock ecu/computer, blitz blow off valve, pod filter, you know, the basics. so this is why this is pissing me off. I've had the car for about 3 years now, and every now and then, maybe once every 4 months, i get this problem with the car stalling when idleing. Its really wierd because it normally only happens after long trips, like being in 5th gear for a while, then when i slow down and start to idle, the revs fluctuate between 0 and 1200rpm, then sometimes it will stall. It happened the worse the other day when it stalled 8 times in an underground carpark. it starts up again straight away though, so there's no problems there. sometimes it will stall and all the warning lights will come on (HICAS, etc) then it will start again without me doing anything. it will only be off for a second but its still wierd.
Now, for what i have done about it.
Today i took it to Gavin Woods Autotech on the coast and he datastreamed it and said that there was nothing wrong with it. so that to me rules out AFM and O2 sensor, which were 2 of my culprits. the most annoying thing is that my car is running perfect now.
so i think that the main options left are the BOV, pod, and intercooling pipe. I should also mension that when i first got the car, i blew the intercooler pipe off and put it back on myself. now i have to be honest, it wasn't the best fitting pipe, but i clamped it on pretty well, and it has never blown off since. i thought maybe there could be a tiny bit of air escaping/intaking from a little gap maybe, but then it would happen all the time right? i think i may also buy new hoses to attatch to the BOV, maybe there's something happening there.
I know there have been a fair few posts about stuff like this, but i have read them all and most seem to have something to do with the AFM, which in my case i know is fine. so if anyone could help and offer suggestions, it would help a lot.
Thanks everyone
https://www.sau.com.au/forums/topic/182529-please-help-me/
if it's the blitz dual drive, increase the spreing tension using the allen key.
I had the dual drive in the S15 and it would stall when stopping with the clutch in...wound up the tension and fixed the stalling completely, without affecting the function of the bov.
https://www.sau.com.au/forums/topic/182529-please-help-me/#findComment-3312420
hey mate, do you increase the spring tention by winding the screw all the way in or winding it out? at the moment i think its out
thanks
https://www.sau.com.au/forums/topic/182529-please-help-me/#findComment-3312460
if i remember correctly (it was a few years ago now) wind it anti-clockwise to increase the tension. You dont need to wind it all the way in....but you will need to give it a few rotations. Wind it in and go for a drive to make sure the valve is still opening enough to do it's job...all trial and error until you get it right.
I think I gave mine about 20 rotations, but the stalling was a lot more severe than what yours seems like. Mine would stall every stop if you didn't blip the throttle on some gear changes or when stopping (valve would open even when not on boost).
https://www.sau.com.au/forums/topic/182529-please-help-me/#findComment-3312472
ok, i ended up winding it all the way in, but i honestly don't even know the difference between all the way in and all the way out. it seems to be a little looser all the way out, but not by a lot. i'm starting to wonder if the spring is even in there? its hard to find info on this BOV too
https://www.sau.com.au/forums/topic/182529-please-help-me/#findComment-3312540
I still think that it's an AFM problem
it won't come up ont he diagnostics because it is working fine at the time of the diag test.
Can you:
1.) Borrow a working AFM from a mate and test it out on yours for a few days?
2.) remove your AFM and clean it as per instructions you can find in this forum?
the reason I think it's the AFM is due to these facts.
*Happens after long drive (as in after a constant flow of steady air)
*revs going from 0 - 1200rpm
I'd be interested to know if you get a violent cut too.
say after a long drive when it starts to play up, if you shift back a gear or so and give it a boot full.
https://www.sau.com.au/forums/topic/182529-please-help-me/#findComment-3323899
Can you:
Hey mate,
thanks for your reply.
first of all, i probably can't borrow an AFM because all the people i know use their cars daily.
I will read up on how to clean the AFM in a second, so that i can do.
the cut outs are pretty normal, like i can feel the revs fluctuate, and i know that she will cut out soon enough. I can't really drop gears and smash it because it only happens when i'm idleing in the worst possible places, like in a drive thru, or underground carpark. anyway, the only thing i could do is nail in in first, but i'm never in the position to do that.
Edited by The White Knight
https://www.sau.com.au/forums/topic/182529-please-help-me/#findComment-3333872
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
