Previous owner over tightened the sump plug. Now I can not tighten it. It simply tightens then loosens, tightens then loosens. Never more than just beyond finger tight.
I tried wrapping it in teflon tape / plumbers tape but that only stopped the leak, hasn't allowed me to tighten it properly.
Now, can i get it re tapped to a larger thread? It is an bnr32 so removing the sump is really out of the question. Assuming it is possible, should i be fearful of metal shards making their way into my sump? Finally, do i need to see an engine builder or can most mechanics conduct this operation?
https://www.sau.com.au/forums/topic/182531-threaded-sump-plug/
Super cheap have a range of bungs going up in size so i dont think you will have any probs getting one slightly larger.
Any spanner should be able to take care of it for you.
i wouldn't use PTFE tape (plumbers tape) on your sump plug. bits of it will break off and get sucked up your oil pickup. you could get it tapped out, as long as there is enough meat there to tap into. i don't think most mechanics would have the tap your after. if you are looking at tapping the hole out also look into Helicoils (thred repair).
1- Try a new bolt.
2- If that fails get it re-tapped.
Does anyone know who sells a quick release valve for this purpose?It would be good to get one fitted
and stop this sort of thing ever happening in the first place.
Good luck and hope the new bolt will fix your problem.
Quick release plugs / tap thingo's really are not a good option mine had one on the car took forever to empty the sump and stripped when removed, bugger.
when tapping a hole swarf comes out as part of the cutting action so shouldnt go in'
thats all we did and still good many changes later with a standard super cheap type sump plug.
As long as the mechanic has the required tap size any mechanic should manage this one and from memory there is a fair bit of meat there to tap
Edited by noone
yep mine was rooted too and had to be drilled out then a new thread cut in. all this can be done in car and no metal will go into the sump. but you will end up with a bigger sump plug obviously and sadly for me the dude doing it chose a bloody imperial bolt so I now have one imperial bolt on my car... sucks :glare:
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
