Hello all,
does anyone of u ever set up a sensor for pre and post intercooler temperature?
What is the efficiency of the intercooler from the test? I am trying to research for new type of intercooling technique but need data of present air - air intercooler to see if it will work.
Hi Lambo, we run 4 air temperature sensors when testing;
one ambient, located in front of the intercooler
one air inlet, located at the air filter
one turbo outlet, located between the turbo and the intercooler
one engine inlet, located just before the throttle body
Thermo couples fit between the silicone hose & clamps and the alloy pipework.
Intercooler efficiency is expressed as a percentage, which I calculate this way...........
intercooler inlet temperature (say 50)
minus
the intercooler outlet air temperature (say 30)
divided by
the intercooler inlet temperature (say 50)
minus
the ambient temperature (say 25)
Thus (50-30)/(50-25) = 80%
We commonly see numbers in the 70's
Hope that helps
Hi Sydneykid,
What boost are u running and wat turbo is it using during the test?
I understand that the air get heated up a lot during boost. Sometime close to 100 degree. Say if we have a technology to make the ambient temp same as the post intercooler temp will that make a lot of difference?
Anyway i notice the figures u have for the post is very good for a IC. Wat brand is it? Does it have a good flow?
The second issue about IC is that they have a lot of drag to cool efficiently. Did u manage to get the pre and post psi of the IC?
80% efficiency is very high... is that a rough figure?
Hi Lambo
The number we posted are for the purposes of showing you how to find out the Intercooler efficiency as a %. As of right now, we have not conducted a test for our intercooler (standard GTR Cooler). This is something for you to do yourself, as all coolers are different.
Obviously, the more you can cool down the air before it enters the engine, the better, but I do not believe there is a single intercooler which can bring the air down to the ambient temp (I may be wrong, but it is possible if you live in Thredbo....)
Hope that explains the numbers
S of S
I am just wondering how safe my setup is on my RB20DET. I'm pushing close to 200rwkw with aftermarket turbo but still using standard intercooler (until i get the funds to upgrade). It was dynoed at 13psi and fully tuned with no pinging (25 degrees ambient approx). I don't know what to exactly be listening for if my car starts to ping....so i usually only give it some stick on cold nights (below 10 degrees). How different would the standard cooler perform on a cold night compared to say 25 - 30 degree day? How long would roughly would it take for the cooler to get heat soaked? What temperature range is acceptable for the air after the cooler?
Regards,
Scott.
MM2Death: As a guesstimate, with a GTR cooler on your car, may achieve more like 220rwkw
The optimum temperature for turbocharged cars and turbo changers in 17degree Celcius - I learnt that about 8 years ago watching the Champ Cars at Long Beach on Channel 10... as an 11 year old... strange the things you remember
S of S
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
