Congrats Jerome...what made you decide to upgrade???? how long before you get the new baby?
congrats again and cant wait to see it, looks bloody nice :)
p.s will this one go faster seens as its real red :P
https://www.sau.com.au/forums/topic/182560-upgrade-me-baby/#findComment-3312511
hehee... shure hope so....... um the reason for the upgrade was this one was goin quite cheap, hope for not the wrong reasons and she seems to have most of my options but in an s2 so triptronic and all the other bits. it sad but good there gettin cheaper. sucks cos i wont be gettin f all for my s1 but good cos the new one is only gona cost a bit more than my s 1 did 1.5 years ago. wat do you reckon a s1 in good condition is worth fully optioned with minor mod. might have to sell it back to the yard from whence she came but i got 6 weeks to try and sell her as my newbie is still in japan
https://www.sau.com.au/forums/topic/182560-upgrade-me-baby/#findComment-3312578
neo and triptronic was the main reason. was just about to pour a few more grand into my s1 and one of them was to lower her and the s2 looks way low, the other was to get my nismo kit fitted and painted so i figgure the money i save can justify the upgrade..... my gf aint to happy though but she seems to nice to say no
https://www.sau.com.au/forums/topic/182560-upgrade-me-baby/#findComment-3314287
you've done well - it looks damn nice!! :laugh:
good luck with the sale, and with the new car :)
Does it feel any different to drive? It looks like it has modified (lowered) suspension so I guess you cant really do a fair s1 to s2 comparison. :)
https://www.sau.com.au/forums/topic/182560-upgrade-me-baby/#findComment-3314470
fair call mate.. always comes down to the almighty dollar!
best of luck with it - looks like a great car
https://www.sau.com.au/forums/topic/182560-upgrade-me-baby/#findComment-3314556
thanks guys. havent driven her yea as its still in japan. i have driven 1 s2 though and found the gear shifts soft. anyone else with an s2 had a shift kit fitted or found auto shifts sloppy
G`day jerone IT`S Slopppy that is for sure,all waiting for valve bodies to be come out ? b plated auto same as r34,this will make it a lot better .looking forward to get mine kitted.good new`s on your new S2you said it was happening ,looking forward to seeing you both.someone will get a nice series 1 good luck,chuckie.
https://www.sau.com.au/forums/topic/182560-upgrade-me-baby/#findComment-3314980
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
