have a set of hollow 19inch axis rims imported from japan, 90% tread left on all 4. paid $3400 from japan. open to offers! over $1800
Axis Reverb - Five spokes and a polished lip hold a lightweight surprise on the Axis Reverb - hollow spoke technology. The Reverb uses a unique casting process that makes each spoke hollow resulting in a lightweight yet very strong wheel. The Reverb comes in sizes for many of today's popular compact front wheel drive cars from 17 and 18 inches, and in staggered sizing for Nissan 350Z, Infiniti G35 Coupe, Lexus SC and GS, Mazda RX7 and RX8 and Toyota Supra. Fitments for cars with factory Brembo brakes like the STi, G35 and 350Z assure a perfect fit over large brakes. Suitable for track use, the Axis 350Z race car uses Reverbs in an 18x9.5 front and 18x10.5 staggered fitment.
Read how Edmunds.com built a Cobra Killer of a Mustang GT and used a set of Reverbs for their light weight and high strength.
Edited by r33gtst-ser2
mate when i look at the picture, and the rims on my car, they look exac the same. but not 100% all i know is they cost me $3500 when i got it from the car dealer, and he got them from japan. tnx mate
ok guys i have found the right ones---- not sure if there 19x8.5, 19x9.5, 19x10.5. the backs are alot wider than the fronts
Axis Hiro - Five spokes slightly narrow on the way to a deep polished lip, then bend back over the lip for an even deeper stance. The Hiro has perfect staggered fitments for Nissan 350Z, Infiniti G35, Toyota Supra, Mustang, Lexus GS, Lexus SC and even certain Volkswagens and more of today's modern sedans and coupes in 19x8.5, 19x9.5 and a huge 19x10.5. The Hiro boasts generous caliper clearance and will even fit over factory Brembo brakes and many aftermarket kits as well. The Hiro is very popular as a staggered wheel, but also has perfect fitments for non-staggered wheel fitments like Acura TL, TSX, Honda Accord, Mitsubishi Evo VIII and IX, Nissan Maxima, Scion tC, Subaru WRX and STi. Now available in 18 inch applications in non-staggered sizes.
well let me know...
also can you please tell me the offset and width... if they are genuine axis they will be in the inner of the rim
Do you have any pics of the wheels on the car??
What brand tyres?
Yes, i am interested but want to know the width and offset. The details in the description don't help. They just give the "possible" size.
Thanks
Bolt Patterns guys i might swap for after market parts for my 33 gtst. im after---dump from turbo to cat---turbo---power fc---ect. let me know what u got. tnx
5x100, 5x114
5x114
thats all the info there is, sorry guys
this is not my car its just a pic of the rims. not sure what size!!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
