hey just trying to sell my evo 9 here are some spec's and pics.
06 Evo 9 done 18,000km with log books and service history, im the 1st owner.
always used motul oil and every 5K service oil and filter got renwed, and just recently replaced standard brake fluid with motul racing brake fluid.
2.0-litre 16-valve DOHC intercooled turbocharged MIVEC engine
3 nozzle water spray for intercooler
Engine oil cooler (air-cooled)
6-speed close ratio manual transmission
Full-time 4WD system
Switchable Active Centre Differential (ACD)
Front helical-type limited-slip differential
Rear differential with Super Active Yaw Control (S-AYC)
Sports Anti-lock Braking System (ABS) with Electronic Brakeforce Distribution (EBD)
Front 320mm ventilated disc brakes with 4-pot brake calipers (brembo)
Rear 300mm ventilated disc brakes with 2-pot brake calipers (brembo)
17 x 8.0JJ Enkei light alloy wheels, 235/45R17 93W ADVAN tyres
Recaro full bucket front seats
MOMO leather-wrapped steering wheel
Auto / manual intercooler switch
Driver’s and front passenger’s SRS airbags
Central door locking system, Engine immobiliser
Diamond TRAC security system (GPS tracking)
Ralliart floor mats
Ralliart scuff plates
Tinted windows,paint and interior protection
Full 5 / 10 year Mitsubishi warranty
10 Year road side assist
Full service history
Mods:
Viper 710vx pager alarm system (installed by northfield car sound)
Full custom stero - Alpine touch screen dvd,alpine PDX amps,Alpine Subs,Focal comp Splits and coaxials and stinger wiring and cap (installed by northfield)
Tomei racing dump pipe and font pipe with Trust titanum cat back system with 3" hi flow cat
HKS Induction kit
Greddy B.O.V
Greddy turbo timer
Pivot electronic boost gauge
All standard parts will be given to buyer (standards exhaust,air box and piping,stero)
Performance : 211kw @ all 4 wheels on Godzilla Motorsports dyno runing standard boost
Asking $55,000 ONO as is with 6 months rego and RWC. will consider selling car without audio gear for less :P
Located in Brisbane
For more info
email me on gtr_083 @hotmail.com
call or sms 0432 733 357
thanks
Nick
Edited by GTR_83
https://www.sau.com.au/forums/topic/182564-fs-06-evo-9/
wreckedhead, long time no see. no spamming other peoples for sale threads thanks. you only get one friendly warning like this so please take note of it.
https://www.sau.com.au/forums/topic/182564-fs-06-evo-9/#findComment-3330211
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
