Hi Guys,
Just a qucik question because i'm at work and can't sort through 50 posts to find an answer...Can someone confirm is r32 rb20det boxes are the same as r33 rb25de boxes? I've heard casual talk here and there that they are and need some confirmation...are they physically identical or with slight differences? Gear ratios the same? any input would be greatly appreciated...cheers fellas....
https://www.sau.com.au/forums/topic/182588-r32-gtst-and-r33gts-boxes-the-same/
33's have stronger boxes..
From what I remeber.. (and please dont take my word for it.. it was a long time ago and was just flipping through the manual).. but.. I think the 33 1st 2nd 3rd gears are SLIGHTY taller.. only by 2-5 teeth..
i dont think that works mate...you can use a 25box behind the rb20...but the 25 box is slightly longer and you just need to make up a bracket to weld onto the std crossmember so it picks up the original holes. Two of the std one will line up and the bracket will let you reach the other two.
you could use th 32 box but i wouldn't count on it lasting long, they're not the strongest of box. your talking about putting a rb25det in a 32 and using the 32 box, tht could be done. 32's and 33's have different final drive (diff) ratio's so your speedo would be out if you put a 33 box on a 32 diff.
i dont think that the 33 na box is any stronger than the 32 box, most people same they are the same but it may only be refering to the gears themselvers and not the whole box because i think they are slightly different
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
