I'd use a thin synthetic say 5W30 or 0W40 (more expensive)
In the old days when I used to read street machine I remember they recommended taking the dizzy out and putting a special tool in to drive the oil pump before starting the motor (ie get the oil pumped around and up to pressure before turning the motor over).
Not sure how necessary this is provided you used lots of oil on assembly
mike
I have primed the oil pump with assembly lube so it will make vaccume and pump the oil through, so that should be ok, mostly just concerned about the oil its self.
So, so far we think that 5 - 40 or better still 0 - 40 will be the go.
anything else anyone?
Not having your car for 6 months really recks your nerves when it comes time to crank her over.
yeh that is a scary moment, i used mobil running in oil, cant remember the weight.
good thing you filed the oil pump up :P i used petroleum yelly, worked just as good
just remember after an hours run to replace the oil and filta :P and load the prick up in a high gear
You dont run synthetic oil in a brand new motor which your running in.
You run some cheap thick oil. If you run synthetic you will do damage to the motor before you run it in.
The reason you run thick oil is so the rings seat and wear in correctly..
Call an engine builder and confirm! What the hell are you guys thinking?
Edited by abu
yep another confirm here...
Run the cheapest oil possible.. the fact is you WANT engine wear to occur during the run in process as this is how rings and bearings bed in. Go grab some black and gold or some equally cheap shit and run that... once motors run in, drain it, change filter and run some decent oil through it.
Black & Gold lollllll
I dont think thats the best way to describe it, nor is it the best idea to buy 'cheap' oil. Thats just ridiculous! Its not the right idea to purposely wear the engine. That is not whats reffered to as wearing in the engine.
The idea is to bed in the rings correctly using the proper oil and proper driving style. A mineral based oil is best from what im told, deffinetly not synthetic! As previously mentioned there are specially formulated running in oils, but its best to consult the machine shop that did the work for you.
A good idea is to remove all s/plugs and wind over the engine until the oil light goes out which means you have oil pressure up.
As far as oil changes go my new forged pistons state to do a change of oil and filter after 500km and to give the engine some work during the first 20km. Im sure its a good idea to load up the engine for alot more km's but id say that the first 20km is the most crucial. By the way that doesnt mean lots of revs, keep the revs pretty low but make sure you use perhaps 4th gear and load it up up hills. They say going for a drive up through mountains is a good idea due to lots of climbing involved.
I too am building up my new engine and will be going by exactly what my machinest tells me to do.
Deren
Edited by Godzilla32
don't keep the revs low and DONOT load the engine up in high gears with low vehicle speeds. Ideally you should give the engine a decent amount of revs anywhere between 3000- 5500 or so up a winding hill to put load on the engine in its peak torque range, don't bounce it off the limiter or go flat sick everywhere. Using the mineral oil to bed an engine in is best as it still contains some impurities which helps to take the top off the peaks left after honing the bores. Theoretically synthetic oils are supposed to prevent any where at all that why it a bad idea to use it running an engine in. Its my understanding that you want to knock the top off the peaks left from honing the bores but not take them completely all the way off. by taking the tops off it still leaves a valley where risidual oil can sit and help to lubricate the rings and piston against the bores.
synthetic will not allow where so in turn the bores glaze and never achieve a good wear pattern allowing oil in to burn. the first 800ks or so are the most important when running in an engine i wouldn't use synth until after at least 5000ks.
thats my opinion hope its useful.
yes the idea is to purposely wear the engine in, that is after all what happenes during the bed in process. During the first few kms the rings must wear against the boors to ensure a proper seal, without this you'll never have a good performing engine.
And there is nothing wrong with a cheap oil for running in motors, there is no difference in running 4 dollar oil or 40 dollar oil during the first 500 or so kms, as the oil is still going to get contaiminated from the wearing in of the various engine parts. Thats why it is crutial to change the oil as soon as the ben in is complete.
As for running in motors... low revs and 4th gear is labouring the engine far to much too early in its life span, your best bet would be 3rd gear and go through hills continually accelerating and decelerating and varying the load via the throttle.
But hey, your machinist knows best ;)
Deren
Coming from someone who doesnt even know how to spell the word 'bore' im not going to take your reply too seriously.
The engineer (John at JHH) that has machined my 26 has built 3-4 RB's alone a week and clearly knows his stuff regarding high performance engines. So yes im quite confident to go off what he tells me to do. Being a mechanic myself i can tell when someone knows what they are talking about and know when not to listen to the comments like yours about aggreeing on using a syntheic based oil for running in an engine. A good quality oil is important in order to not wear other components such as bearings. Afterall the there is more to lubrication than just cylinder bores. A crap oil will not protect bearing surfaces as well as a quality oil does and will not resist the same pressures.
By the way i didnt mean use ultra low engine rev's when loading it up. Normal driving rev's with varying loads.
i never said i was agreeing with the use of synthetic oils during run in. I was however suggesting that cheap mineral oil is just fine.
Please tell me how a crap oil is not going to protect a bearing surface? vIm sure that your aware that when new bearings are used there are highs and lows on the surface, and part of the bed in process is to wear down the highs so that the surface is uniform.
Im a mechanic myself, i know how to spell bores, typing is not my forte however.
i build engines.
Use a straight oil say 30 weight or 40weight.. thinnish.. make sure it has no friction modifiers so the rings and bearings bed in properly without glazing the bores. Dont let it idle for long (5mins+)
Dont baby the motor (u will only make it a baby for life, less power than others of same engine and so forth)
Dont load it too much
Dont over rev the engine. Hitting the limiter or even going near the redline can have severe consequences.
Dont load the engine down low, less than say 3000rpm up a hill..
Dont Boost engine above standard.. so running 15psi instead of 7psi...
Do drive the car under varying loads.
Do drive it reasonably hard sometimes (that doesnt mean WOT and redlines. just like around 75-80% throttle and around 5k-6k rpm
Best thing to do would be to have the car on a dyno and load it to around 150hp-200hp with varyin revs for around 2 hrs and thats all :D
Edited by Bumblebee
BumbleBee : cheers for that, you clarified what I was thinking... the only other question is how long must I run the engine in before I change the oil?
then to what oil? I understood that I needed to do so for 2000 to 5000 ks.
also someone suggested that going from mineral oil to synth oil would cuase it to curdle, but I don't see how that can occur.
any help?
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
