300kw at all fours gtr
Guest dazza400kw
G'day everyone.I have a R33GTR vspec which has 300kw at the wheels at 1.2bar of boost. Came from japan with all the usual bits,eg 31/2" exhaust , very large trust intercooler,pods,Greddy boost controller, guages galour and a hks fconv pro (which i have changed for an unichip). Could of been a street drag car as i have just had to replace the front transfer case and found the clutch was a twin plate "AGURA" racing clutch with plenty of "very hard" launch marks on the custom flywheel and other facings. Is this typical output for a car with such mods as the turbos look to be stock. :burnout:
https://www.sau.com.au/forums/topic/18264-300kw-at-all-fours-gtr/
u mean ogura clutch??
if the power figure is 300kw @ all 4 wheels, then i would think the turbos are high flowed at least.. even 300rwkw is bit too much for stock turbos i think... :D
any reason why u changed the management system to unichip?? (just wondering thats all)
ps : i just read the post title.. it clearly says 300kw at all fours... :P
Guest dazza400kw
Thanks guys.
In answering the question asked by nissaner the unichip was the way to go over the fconv due to the fact i live in tasmania and the only guys that tune fconv in australia are the boys at bd4 in sydney. It was running very rich and its interesting to note the vehicle actually had 240kw at the wheels with the fconv , 236kw with stock computer and finally 300kw with the unichip (after several hours of remapping timing and fuel maps),so the only use of the fconv for me here in tassie was the ability for speed limiter removal and 9000rpm rev limiter. I have all the dyno sheets here but haven't worked out how to add to the posts and i can't get access to the gallery. "ogura", thanks for the heads up.
ps. the power figures are all at 1.2bar of boost and when i first drove the car it was running 2.0bar!!!!!!! but didn't seem to have the get up and go as i have now.
If anyone out there wants the fconv pro you can have it CHEAP!!!:burnout: :devil:
Not possible unless they have been hi-flowed. 2 bar on stock ceramic wheel turbos would be certain death to them. I think even 2 bar on hi-flowed standard turbos wouldn't last long. They are probably aftermarket like HKS or Trust or something.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
