Used in perfect condition Microtech Efi LT 12s RRP $1495
(Top of the range with all features)
For Nissan Skyline R33 S2 Gts-t
With Plug & Play adaptor RRP $350
(No wires need to be cut to install this ecu)
Software & Dongle & Cable RRP $155
(software needs to be run on a laptop - I used a dell with Win XP)
Full RRP $2000 so pick your self up a bargain at my expense
http://www.microtech-efi.com/index-2.html
This ECU has been tuned using the matrix mode for fuel economy and power all on the one tune.
I used to get up to 550km / tank on the freeway and about 400 around town if I drove nicely, however with the 255l/hr fuel pump, 1:1.7 malpassi fuel regulator and 17 psi putting out 250kw@rw it could use the fuel up in about 250km when I wanted some excitement. Unfortunately that was quite often.
If you have same specs straight up as mine your tune should be pretty close, but please check your a/f ratios on a dyno before using it.
My engine/power mods were:
Stock Engine Internals
Apexi High Flow Air Filter
GReddy Profec B Spec 2 Boost Controller
(Shouldnt matter which one your using)
Split Fire Coils (blue) (I still have these for sale if anyone is interested email me & I can list them for you)
These were great as they allowed a much larger spark plug gap which increased lots of high RPM power for my car.
NGK Irridium IX spark plugs with 0.8mm gap
(Could only get a 0.6mm gap before using Split Fire Coils before getting spark blow out from high boost)
Boche 255 L/hr Fuel Pump
Malpassi 1:1.7 Fuel Regulater at 40psi at idle (I think- it was on the gauge)
Apexi Turbo Timer (Includes a useful A/F ratio meter good for tuning your fuel economy to 13.5-14.8 : 1. Don't tune for full throttle on these as they are not as accurate up high)
Hybrid Tube & Fin - Front mount Inter cooler
GFB Hybrid BOV
Greddy Oil Catch Can
3" Mandrel Bent Stainless Steel Exhaust - Turbo Back with high flow cat.
And a High Flowed with steel wheels - T03/04 from an R34 after I blew my stop plastic/ceramic one at only 12 psi.
ASKING $1600 LIVE ON THE GOLD COAST DAN - 0423344478
Edited by ragex
https://www.sau.com.au/forums/topic/182651-fs-microtech-lt12/
  • 2 years later...
GFB Hybrid BOV
Cheap
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
