I spoke to a mate i work with today (he's been on holiday) who won 2 trophies for his Mirage at AutoSalon. One of his Trophies was taken after the presentations on the sunday.
Unfortunately he has been told by someone that it was someone form the "SKYLINE CLUB" that took it. I defended everyone involved with the SAU displying knowing most of the people involved i no one here would do anything like that. He didn't specify SAU he just referred to it as the Skyline Club.
AutoSalon are sending him a replacement trophy.
I don't think it helped when i told him we won enough we didn't need anymore :laugh:
https://www.sau.com.au/forums/topic/182686-stolen-auto-salon-trophies/
  • Replies 53
oh what! As if ANY of the entrants with sau wouldve done that!! Like Luke said - alot of crap went down afterwards with queen street etc, other trophies were stolen too from what ive heard.
Seems someone wants to cause some trouble. Thats sad :laugh:
but good response from u lol
people need to have proof before they start accusing people of stealing stuff. i really dont believe anyone from SAU or the R31 club would steal someone else's trophy. its bullshite.
queen st were the one that caused the trouble on sunday after the presentations, but they have been disqualified since due to a judge being hit.
I total agree and said that to him. He has been going off second hand information as he has been overseas for the last few weeks.
He also mentioned this due to their car not being judged correctly or something.
im sorry but i dont believe that queens st's excuse for stealing a trophy is that their car wasnt judged correctly. i think it was more the fact that they expected to win, and when they didnt they went and stole someone elses trophy
sad very very sad. and they should be ashamed of themselves.
skyline club would be SAU, who else
umm...is that Sambo kneeling behind PK?...damn hot thing :thumbsup:
Other skyline club is the R31 club, but I REALLY doubt it would have been any them either. They had their own award too, so seems someone is just shifting blame and looking for an easy scapegoat.
The person stealing trophies is and adelaide skyline that displayed by itself and has nothing to do with SAU.
I will not name anyone but i am sure some of you might be able to work it out.
Yes, Queen street have now been banned from Autosalon for good for threatening a judge and almost causing an all in brawl at the end of the night.
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
