Guest RedLineGTR Posted June 14, 2003 Share Posted June 14, 2003 About a month ago purchased a k&n pod filter for my r33 gtst...recently it seems to be loosing it colour....some of the corner are going white...i have the recharge kit and have noticed that the oil that you treat the filter after you wash it, is red.. Since i only purchased the filter a month ago or so, would the colour of just faded away abit from the engine temps if so i assume that the oil is still in the filter element only the colour has faded away..?? Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/ Share on other sites More sharing options...
payaya Posted June 14, 2003 Share Posted June 14, 2003 never really had that problem with my pod. It only turned a dark colour from the dust etc. Maybe you didnt spray enough of that red oil onto it? Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-381797 Share on other sites More sharing options...
carlo Posted June 15, 2003 Share Posted June 15, 2003 Pull it out, wash it, dry it and re-oil it.. Because its new it most likely soaked up alot of oil Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-381879 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 Thanks for the advice. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-381922 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 MIght as well clean the AFM while i'm at it... Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-381924 Share on other sites More sharing options...
payaya Posted June 15, 2003 Share Posted June 15, 2003 i read the proper procedure to cleaning an AFM, but isnt there netting there??? cause i remember there is. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-381992 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 did you want to know how to get it out or did you want to know what to clean it with... Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-381994 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 1. disconnect your AFM from the pipe that leads to the turbo 2. unbolt the airbox (if its still there) so that the piece conneted to the AFM is loose the afm and half the airbox should come out together 3. get some break caliper cleaner/ electrical contact cleaner from supercheap auto 4. hold the AFM upright and spray in small bursts into the AFM onto the element which you should be able to see. don't use too much - keep it for next time 5. let it dry (should not be long) and reverse the order you did to take it out to get it back in your AFM is clean! now all you have to do is reset the ECU and your right as rain! (Sometimes the reset helps more accurate calculations) Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-381998 Share on other sites More sharing options...
payaya Posted June 15, 2003 Share Posted June 15, 2003 sorry, i know how to do everything but isnt there fine mesh sealing off both ends of the afm? Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382001 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 yes put you can spray it threw the mesh....some people have removed the mesh..may add abit of power but not much...personallt i would not remove the mesh. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382004 Share on other sites More sharing options...
payaya Posted June 15, 2003 Share Posted June 15, 2003 ah thanks thats what i wanted to know. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382005 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 no worries. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382011 Share on other sites More sharing options...
dru32 Posted June 15, 2003 Share Posted June 15, 2003 newbie question... wots the afm.. wots it stand for. n wots it look like? Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382013 Share on other sites More sharing options...
payaya Posted June 15, 2003 Share Posted June 15, 2003 a flying moose nah joking Air Fuel Meter its that thing with the wires coming from it before you air filter. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382024 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 lolz dru Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382054 Share on other sites More sharing options...
fooey Posted June 15, 2003 Share Posted June 15, 2003 How tight are the police in Melbourne about oil pods? Have you got yours in a sealed box? Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382102 Share on other sites More sharing options...
payaya Posted June 15, 2003 Share Posted June 15, 2003 nope Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382108 Share on other sites More sharing options...
Guest RedLineGTR Posted June 15, 2003 Share Posted June 15, 2003 nope...even if its sealed they still will defect your for it, heard this happend in some cases. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382127 Share on other sites More sharing options...
dru32 Posted June 15, 2003 Share Posted June 15, 2003 Originally posted by payaya a flying moose nah joking Air Fuel Meter its that thing with the wires coming from it before you air filter. Whats an air filter look like? jokes Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-382267 Share on other sites More sharing options...
payaya Posted June 15, 2003 Share Posted June 15, 2003 its that belt under the timing case, cut it off remove it, then start your car. Link to comment https://www.sau.com.au/forums/topic/18273-kn-pod-filter-question/#findComment-383165 Share on other sites More sharing options...
