Hey all just a couple of things lying around that need to go.
Complete Long Motor $2000
Bottom end $1000
Cyl Head $1000
LH Tail Light (black) Slight damage to indicator part) $50
Standard BOV $40
Open to offers on all of the above.
Cheers
https://www.sau.com.au/forums/topic/182737-r33-gts-t-bits-peices/
