  • Replies 119
Originally posted by b005t
old r33 - had jap rego sheet in glovebox, certificate for the kakimoto exhaust (jasma), flare still in bracket (took that out, its in my room), original jap skyline user manual, some certificate rego or when the car was purchased, wrapped in clear plastic, original nissan security sticker. also had this air purifier on the rear parcel shelf, with a remote control in centre console, couldnt get it working though. oh and also original gearknob in the glovebox hell yeah!
new r33 - flare still in car- took it out, original manual in globebox, car was really clean when i got it inside, they must have checked before selling it, also later on found extra tein C spanner for the coilovers under the spacesaver in the boot, also a piece of my rear guard sitting under the tyre which is chipped off.
thats about it ;)
b005t,
what you describe above is spookily IDENTICAL to what came in my car.... was your Jap dealer Nissan Prince in ***uoka ??? Shame 'bout the Puretron not working 'coz i'ts very practical rice (which I wasn't expecting by the look of it).
I found a Endless break pads box with the old set rusted pads down the side of the boot...near the tool kit....and also a fuel receipt underneath the leather gear leaver cover.
...OH AND A FLARE :D...haha to everyone without flares
My Flare was located underneath the carpet on the drivers side...it also had some weird alcohol can in the console...
....I wish i found a japanese playing card...:D
Mine came with a Castrol service sticker with (the writing had been rubbed out but left an imprint on it that was visible) .... it said next service due in Aug 02 or at 104,000Km ........ hmmm funny that as the odo only read 75,000kms as of Aug 02 :P
Also have some labelling tape on the doorwell with some jap writing on it ..... no idea what it says.
But other than that - its been fairly boring ..... no playing cards, no dockets ..... nothing
Originally posted by coco69
did you guys have the tyre placard with original wheels specs on it?  the one on the drivers side door.
isn't it like RWC mandatory?  coz i dont got one...
oh i got one of those :P
my oil filter had a penis drawn onto it...
oh wait a minute, i drew that...
but my car came with some pretty new looking sparkies that were PFR5A's... and when i read listings about sparkies i couldn't find that number so i chucked em out and replaced them with NGK coppers that were listed for the skyline... only to later on realise that they were new NGK platinums... :'(
Originally posted by BigDatto
b005t,
Not sure about the dealer, couldnt find that written anywhere, well theres stuff written in pen and stamps, but its all in jap!. But yeah the puretron wouldnt work, haha.
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
