Hey, Pretty much as the topic states. After alot of thrashing and pushing to it's limits my motor has finally decided to lose compression in one of it's cylinders. Now it's an r33 gtst with an rb25. So my delema is whether to rebuild my motor from the ground up with forged internals or save a bit of money and drop a second hand motor into it.
what do you guys think, i'm after honest advice and any help people can offer..
Also if anyone can recommend shops to get quotes from and feedback on shops who have done this type of work.
thanks guys
https://www.sau.com.au/forums/topic/182764-need-advice/
  • Replies 61
if you rebuild the motor, your going to have a nice new forged engine that will last you donkeys years. Buy a 2nd hand motor and its going to be a gamble as to how long it will last. specially if you want to go on thrashing it.
rebuild ftw !
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315375
If all you want is a reliable car to drive around in and you'll give it a bootfull occasionally, then a properly-checked second hand engine would do the job perfectly well and would be cheaper too.
Depending on what's wrong with the engine you already have (it could be a blown head gasket, rings, bent valve, whatever) the third option you might not have considered is to do a repair - sort of a rebuild but without going the whole hog. Fix what's broken and get it going again, keep the stock pistons etc.
From the sounds of it though, you'll be treating it like it's been stolen so a rebuild would be the go, it'll cost you more but you know what's in it, you know it's fresh, and if you're going for bulk horsepower later on and you already have an engine capable of handling it, you're set.
Up to you really, but it depends on what you want to do with it :thumbsup:
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315449
thanks guys
yo brenton.. so it was low compression..?? hehe i knew it..
bugger. did u contact dan with the number i gave u.
if u need some help let me knw bud..
and as if u drive an AUTO
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315940
$10,000 to get an rb26 runnin with my auto.... $7,500 approx to do rb25/30 hybrid... $6,500-$7,500 rebuild with forgies, Approx $4,000 rebuild with stocko parts, or approx $5,000 2nd hand motor
It was $10,000 for MANUAL 26...and I told you would have to learn to drive a manual :pwned:.
And my quote for the rebuild with forged pistons and 20thou overbore was $5055.
Cheers,
Andrew
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315954
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
