Hey, Pretty much as the topic states. After alot of thrashing and pushing to it's limits my motor has finally decided to lose compression in one of it's cylinders. Now it's an r33 gtst with an rb25. So my delema is whether to rebuild my motor from the ground up with forged internals or save a bit of money and drop a second hand motor into it.
what do you guys think, i'm after honest advice and any help people can offer..
Also if anyone can recommend shops to get quotes from and feedback on shops who have done this type of work.
thanks guys
https://www.sau.com.au/forums/topic/182764-need-advice/
  • Replies 61
if you rebuild the motor, your going to have a nice new forged engine that will last you donkeys years. Buy a 2nd hand motor and its going to be a gamble as to how long it will last. specially if you want to go on thrashing it.
rebuild ftw !
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315375
If all you want is a reliable car to drive around in and you'll give it a bootfull occasionally, then a properly-checked second hand engine would do the job perfectly well and would be cheaper too.
Depending on what's wrong with the engine you already have (it could be a blown head gasket, rings, bent valve, whatever) the third option you might not have considered is to do a repair - sort of a rebuild but without going the whole hog. Fix what's broken and get it going again, keep the stock pistons etc.
From the sounds of it though, you'll be treating it like it's been stolen so a rebuild would be the go, it'll cost you more but you know what's in it, you know it's fresh, and if you're going for bulk horsepower later on and you already have an engine capable of handling it, you're set.
Up to you really, but it depends on what you want to do with it :thumbsup:
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315449
thanks guys
yo brenton.. so it was low compression..?? hehe i knew it..
bugger. did u contact dan with the number i gave u.
if u need some help let me knw bud..
and as if u drive an AUTO
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315940
$10,000 to get an rb26 runnin with my auto.... $7,500 approx to do rb25/30 hybrid... $6,500-$7,500 rebuild with forgies, Approx $4,000 rebuild with stocko parts, or approx $5,000 2nd hand motor
It was $10,000 for MANUAL 26...and I told you would have to learn to drive a manual :pwned:.
And my quote for the rebuild with forged pistons and 20thou overbore was $5055.
Cheers,
Andrew
https://www.sau.com.au/forums/topic/182764-need-advice/#findComment-3315954
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
