Hi all,
I've got a R33 S2 and I'm looking to upgrade my exhaust to either a 3" or 3.5" turbo back exhaust.
I've apparently already got a HKS cat back exhaust, not 100% sure on size however. (only got the car Monday night).
What's my best bet? Should I just go to an exhaust shop and see what they can do for me? Should I keep the HKS catback and mix in other parts or would it be better to order a certain full TBE package from somewhere? I'm happy to support SAU suppliers if this is the case.
I'm in Brisbane if that helps.
https://www.sau.com.au/forums/topic/182781-upgrading-exhaust/
Thanks for the replies.
Looking at the Just Jap website, would this combo be a good option to use with my current HKS Catback.
JJR Split Dump & Front Pipe - Nissan Skyline R33 GTS-T Price: $269
High Flow Design - 3 inch Stainless Steel
X-Force 3 Inch High Flow Cat - Nissan Skyline R33 Price: $199
Flanged - Flows up to 570 CFM
Would such a system be legal - db wise?
Edited by Simmo1985
If your current exhaust system is quiet now, then after you add the dump/front pipe and high flow cat it'll be the same. The cat back controls most of the sound.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
