To install the os str2cd twin, what additional peices will i require?.....will i need a release and sleeve bering kit aswell like the other os giken twins?.....i just want to price up everything going from a single plate to a twin plate clutch with all parts included, thanks.
You will find that all clutches should come complete with the release bearing ( its a must change when you do a clutch) and all twin plate ( or multy) come with a flywheel too. The only other thing you will need is a spiggot bush and if you want a larger slave with a Nismo twin .
If you go the OS go for the STR clutch, not the competition. If I was you I would use the Nismo , not much different in the cost .
thanks, ive decided on the nismo twin coppermix 640ps, plus nismo fork pivot, braided line and larger slave, might aswell do it all while its open.Is this overkill for a gts25t only runniong and aiming for up to 250-260rwkw?
Edited by nsta
We are on our second OS Giken twin in our GTST. Great clutches, nice and light, easy to use. I wouldnt touch a second hand one though, allt he second hand ones seem to be in need of a rebuild kit and I know numeorus people who have been burnt buying used twin plates.
250-260 RWKW thats a lot of power, more than double stock power . You could use a lot of different clutches to hold this kind of power but let me tell you the Nismo will hold it easy and it will be very easy to use, it will last a long time as long as you DON'T ride it .
Just found out the clutch I'll be getting is a TS2BD. Got some pics, will upload soon.
This is what it looks like:
http://www.osgiken.co.jp/pro_clutch/clutch/ts2bd.html
I've got an OS twin plate in my 32 GTR running 270 4wkw and works a treat. It does take a bit of getting used to if you havent used one before or a button clutch, but after an hour or so you'll have it down pat. Not hard on the legs at all, though I have been driving trucks for a while and my R31 daily driver has a exedy heavy duty clutch so you could say my leg has been 'conditioned'. The couple of people who have driven the GTR though and dont normally drive a car with an aftermarket clutch had no problems apart from trying to let it out too quick with not enough revs :blink:
Cheers!
Gagz
well after driving if for a while... I gotta say...
I LOVE IT! I LOVE IT! I LOVE IT! I LOVE IT! I LOVE IT! I LOVE IT!
lol altho if I'm the first at the lights people think I'm being a trafficlight racer each time I take off, and if I'm not first at the lights I gotta leave half a car length so the car dosen't launch into the back of the car in front. But its sooooo nice now... my ATTESA has a field day every time I change gears. And nowhere near as heavy as I expected... had a heavy duty single plate before it, so it's just a touch heavier than that.
Although, the clutch snapped the Release Pivot (i'm guessing it had some wear on it from the last heavy duty jobber), so the fork was wobbling around and not disengaging the clutch properly. had to wait a few days to get the Nismo release pivot, which they recommend for the Nismo twin plates etc. Apparently the stock carbon steel one tends to break when used on twins and heavier. The Nismo ones are chromolly steel and apparently 30% stronger.
Big thanks to JDM Concept for getting it to me really quickly.
I've got the STR2CD 215mm plate twin plate clutch in my R33 gearbox. it is super noisy when you push the clutch pedal in to change gears. All the comments about it handling power and "you'll get use to it" are correct though.
It's embarrasingly loud for a street setup :laughing-smiley-014: , easily audible over a loud'ish 3" exhaust system.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
