  • Replies 67
So has anyone booked?
Are the people going down the day before gonna have group booking? If so Im in, I can sleep anywhere, as long as there is a shower and it works. Unlike the dredded wakie no shower in morning makes me cranky day.
someone designate a meeting point please....I don't particularly enjoy driving down along and getting lost on the way.
Krispy Kremes, Liverpool?
Thats on the way for me, not sure if it works for others . . .
someone designate a meeting point please....I don't particularly enjoy driving down alone and getting lost on the way.
James, if you're still living in Seven Hills, I was chatting to the Coasties last night and we might meet up at one of the servo's on Abbott Rd (most likely the Caltex/Hungry Jacks/Red Rooster), then jump back on the M7 to head down in a group. It's convenient for me (and you?), and they can just jump off the M2 and meet us there.
Where abouts do you live, Greg? If you're in the Hills, meet us as above, maybe?
I'm driving down on the day so if anyone would like to passenger with me the company would be appreciated.
I'll be solo too (at this stage), so I wouldn't mind a passenger too.
Still living in the hills but got no e tag, so looks like i'll have to meet you guys on the free way down south instead. Unless they have toll booth which I highly doubt.
Pre- or post-pay, James?
I'm all up for meeting at krispy kremes liverpool (also helps out non e-taggers out) at 11am on saturday for those of you heading down a day early let me know so we can wait. still not sure on accomadation tho. waiting on pax.(one has relatives down there)
Looks like Ando is on with us now. We're booked at the Eagle place Jess recommended. Its working out to about $30 something a person so its worth going down early and not having to get up at an absurd time Sunday morning.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
