hi im looing at getting rid of my SAFC2 and upgrading to either of the above... what u guys recommend ? the current mods i haev and the mods im pretty sure im sticjking with.. dont think ill get anew turbo or larger injectors but *may* but i doubt it get them in the future.... so future expansion isnt a realy requirement just wanna get the most out of what i have.. currently have 182.7rwkw as dynoed a week ago with the following
R33 GTST (95 mtype)
stock EVERYTHING except:
full exhaust including high flow cat
pod filter mounted outside engine bay
FMIC (large one :O)
bleed valve at 10psi (holds very strongly for a bleed valve)
SAFC2
NGK platinum sparkies gapped to ~0.8mm
thermo fan that replaced stock clutch fan (16cm) set to ALWAYS be on
so yer what do you guys think is a better option
emanage with e-01 boost control (i also have a laptop)
or a powerfc with hand and boost controllers ? the powerfc with everything is only ~$400 more than the emanage and e-01 so i dont really care if the powerfc is better the 400 is easily justifiable... and vice versa
where to get the choice i go for tuned etc ? was thinking ice performance coz i got dynoed there and they seemed to be switched on.. unlike some other places that remain unamed have proven to be these past few months.... hehe
so yer after reading my essay please help in my choice :D:D:D cheers guys
also is it ok to block my stock BOV to getthe kool flutter noise ? or is an aftermarket BOV a better way to go for cool noises as im sick o the whoosh the stock BOV gives its just so weak lol
Out of the two, i would definately go the power fc. A much better, proven, combination.
If your reeeeally want the cop seeking attention go the atmospheric BOV. If you want to damage your turbo keep the BOV blocked and have the "cooool" fluttering noise (lol).
Otherwise be smart and stick to the plumb-back system :D.
My 2c
Alan
everyone ive spoken to today has recommended the emanage over the powerfc coz its heaps easier to tune (therefore cheaper) especially for my purposes as im not going any major upgrades.. leaving most parts stock... hmm interesting... more replies cmon peeps wanna hear what everyone has to say...
Is the e-manager a replacement ecu or a piggy-back?
Also:
Is it a direct plug-in?
Does it have the same tunning resolutions as a pfc?
Any modifications required to adapt it to you car?
Does it have the same features as a pfc? (Do you need the extra features that the pfc may offer?)
I don't know much about the e-manager, but these are the things to consider when justifing the $400 differance.
AI,
It is like a piggy back but, different. The wire in is easy and the injector harness ect. is dead simple.
Tuning resolution wise it has enough load points and then some for street use.
No mods required to adapt to car.
It has a few more features than the pfc when coupled with the E-01.
The emanage system has been used very successfuly on many a very fast vehicle. Having said that there are a few areas where Trust have had to re-develop. One area is the automatic trans nissans.
Look like the people in the know are the best to listen to, so go the e-manager :D
But i still stress, that you MUST unblock your BOV! I personally think that you mechanics advise/reasoning is dead wrong!! What do you say rev210?
yes it is unblocked at the moment and im going to keep it that way.. but my next question is if i get an aftermarket BOV... do i then disable/block my stock one ? or alwayskeep that untouched and addon my atmospheric BOV ad tune the emanage so that i dont get stalling ?
Your aftermarket BOV will replace your stock BOV. If you really must run a aftermarket BOV, i would recommend the GFB stealth. You can have them fully venting, or plumback @ the flick of a switch.
http://www.gofastbits.com.au/stealth.htm
I wouldnt bother personaly, keep the stockie. You get enough attention from the cops just driving a import, dont give them another reason to pull you over.
Cheers,
Trev
There are a few different adjustable BOV's out there.. I think an adjustable one is the best option if you must have a BOV.
And a p plater at that :) I give him less than 2 months soon as he sticks one on.
I'd lean towards the PFC still.
Agreed that the e-manage is a good unit and has proven good results, but so has the PFC. And it really comes down to the tune.
I just like the idea of a full ECU swap, instead of something that wires into the stock ECU and fiddles with the inputs to the stock ECU.
And if you get the E-01 (for the display) your up for another $700 or what ever they are.
Good luck with what ever you get, I'm sure either of them will give you good results over the stock crappy ECU.
J
Guest INASNT
go PFC with hand controller (i got 1 sitting in my room) coz so much easier to install and u can monitor everything with the hand controller.
Also with the cop and epa situation these days if they pull your kick panel off they there is loom of wire that has been spliced into with a piggy back system u will get done, with the pfc they wont notice. Also the first thing they check now when they open your engine bay is the operation of the afm, e-manager has a map sensor doesent it?? u will get done again.
yer i spoke to ice performance today.. they recommended the powerfc and they do AWESOME work so im going to go the powerfc with hand and boost controller... as for BOVs i rekon that stealth one sounds awesome at the flick of aswitch... stealth is what im all about :P
Hahahahahaha!!
With that HUGE intercooler and the server mods to your front bar, i think stealth is out the door.
Car looks bloody great, thou i would definitely not call it stealth.
That gfb BOV, looks like a load of crap. Once the cops open the hood and see that trumpet, they will give you a canary. Same principal as a removable silencer in the mufler.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
