Custom Yellow R32 Skyline (with R33 Gtr Running Gear)
I have an older ZWNAV 12" in my v36 sedan. Best thing I ever did with it was ditch the stock launcher and install Nova Launcher from the play store. I have the same issue with the screen & sunglasses. I remember reading on a message board somewhere that someone made a screen protector that fixes it. If I come across it again i'll post.
Probably yes. I think I could make it work but I'd rather not chance it. I've been having to ask friends for help because the transmission is just that heavy and for the price of ~30 USD I can get the OS Giken one in soon which should guarantee that clutch alignment won't prevent the transmission from seating properly. -
Coud be the brand. Have never had problems with the shafts I've used in Australia. Even the cheap ones.
I'm pretty sure it's just this specific Dorman one. I checked it with the hub by itself and even then it was already shedding plastic. It's only once I ran into all these issues with assembling the clutch that I decided to be skeptical of the plastic alignment tool as well and found it to have a notable amount of slop as the clutch is heavy enough to allow the plastic to bend. -
The "one cylinder is 160 while others is 180" part of the compression test sounds bad. That's 12% lower than the others. I would bet something has happened there.
