Hey luke.. :)
$20-$30 at a local crash shop and they can aim your lights correctly (down a tad).
On corner entry they were hammering my side mirror blinding me and on the straights it felt as if the interior of my car was lit up.
I waved you past when first heading up in to the hills, on the way back you ended up behind again and I almost missed a corner because I simply couldn't see.
  • Replies 107
hey mate, sorry about that. is it something i can do myself? they even passed regency like that. i will have a look at it tonight cause i dont wanna be causing crashes cause of my lights.
pm's have been sent to those who have asked.
cheers luke
Hey Richo remember the last one you came out with us, you ran over an put your steering wheel back on when they mentioned anyone on defect, that was a good effort :)
lol, yes that was gold!! I was shitting my pants though :bunny:
I wont be able to make it to this one though, I have a drift practice at mallala tomorrow morning and still have to do a few things on my car tonight, but have fun out there! keep it safe
Cheers
Ric
cheers luke
Its all good.. :)
I don't believe they test headlight height at regency. Just operation? I could be wrong though.
I've re-aimed my lights in the past. I usually pull up ~ 1.5meters away from a fence; mark a line that is level with the top of my knee and adjust both lights so the top cut off line is level with that. Take it for a drive and make sure my lights aren't shining up in to the back window/interior of the car in front. Over bumps etc its ok to have the occasional flash in to the interior.
A normal commodore sedan you should see the cut off line ~ level with the middle of their rear brake lights.
You'll know what I mean by cut off line when you start adjusting; at the moment I don't think you would see a cut off line as they are pointed up.
When mine was at the crash shop being sprayed some time ago that's how the bloke told me to do it.
Yeah we mite not be cruising, but may come to meet to say hello!
Richo - see ya tommorow! Day time prac = good footage! Ill make sure i get lots of ya :)
Yes I cant wait, its going to be awesome! Ill make sure I bother you to get that footage of ya :bunny: , Im organizing an incar camera as well so cross fingers I can get that sorted tonight.
Ric
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
