get a 460ohm resistor cut the positive side of the led the longer leg trim the resistor solder it on wrap the diode legs around that white plastic plug thing the same as the original bulbs and youre done plug it in if it dont light up turn 180degre and bobs your aunty :cheers:
https://www.sau.com.au/forums/topic/183041-ac-led-buttons/#findComment-3322240
here are the pics...
left is the original bulb, middle is LED, right is chopped LED
here is when the LED in the holder.. the holder has been chopped (modified) a bit .. to fit the LED
no resistor was used..
yes there is in the blue cover ont the led obviously dan666 gets em made up wid the resistor already on
P.s if a LED does not have the correct resistor it will burn out coz they run on 3.3 to 3.2v so the resistor converts 12vdc to 3.3 or 3.2v if you know what i mean hey!!
so you really dont know what your talking about!! see the 1st pic look close see the shrink wrap in the blue t5 wedge thats the resistor there i thinkwraped in black shrink wrap correct me if im wrong plz :D
Edited by R334door(s2)
https://www.sau.com.au/forums/topic/183041-ac-led-buttons/#findComment-3323706
i mean... in the link posted above.. you're required to solder a resistor on the LED.. these LED doesn't require you to solder any resistor on.. i think you're misunderstanding the question.. or maybe its me.. misreading it.
easy ask 666dan if there are aNY RESISTORS IN THE T5 WEDGE BULB 4 THE a/C BUTTONS
THERE IS LIKE 3 OR 4 LEDSD IN THE BLUE CASE DUKI PLZ FIND MORE INFO ON IT WHEN YOU DONT KNOE HOW DUMB R U
https://www.sau.com.au/forums/topic/183041-ac-led-buttons/#findComment-3324042
omg ... something is wrong with your head..
i know that a resistor is required.. I am saying that no extra resistor are required to be soldered on..
eg.. this link as posted above.. r33 LED
you know what.. I'm not gonna bother arguing with you.. as i definitely knows what you're trying to say..
he bought the same LED off 666DAN like me.. and all he wanted to know was if his required to solder extra resistor on.. but 666DAN has made it easy.. so his not required to..
i just posted some pics up so its better to understand what i did.. that is all.
Edited by ducki
https://www.sau.com.au/forums/topic/183041-ac-led-buttons/#findComment-3324535
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
    • Welcome.  Here's what I have noticed about forum vs FB..... FB; seems to be wallet racing, and the same few questions asked over and over. There *may* be some groups that are closer knit, but most have changed for the worse. SAU; unfortunately, no longer in its glory days. But....genuine people with similar interests. Not all about how much you spent and saying you dont have enough power. Sooooooo much knowledge available. Have personally seen people post up about literally topics I made myself, asking on FB like no one has done it before. Most has been done, and most of that is here.   If you ever feel like just general chatting theres the wasteland.  Other interests are also generally covered in other areas of the forum. Hope you enjoy hanging around. We would love to have you.   P.s. nice 32 😀
