Test You Internet Speed
Pal
 Share
  • Replies 98
Posted Images
Ive tested schools due to a friend that works for the EDU dep. They are getting much faster speeds than your average residential house as you would presuem.
"Telstra Bigpond 8mb ADSL2"
Thats ADSL1.
ADSL2+ is rated to 24mbps, you may experience 8MB but if thats what your net is rated at then its ADSL1.
Telstra lumps its High speed ADSL1 and ADSL2+ plans into "High Speed" so unless you talk to the activations department, you probably didnt choose.
I'm on Westnet 1.5MB.
I was on that until 2 months ago-ish
Changed to AAPT because they offer unlimited downloads between 8pm-8am on the 8Mbps plan.
For us WA geezers it's 5pm-5am
:P Fkn Grouse!
Edited by Topaz
It wont let me try it from work, however when i download at home via bitsoup.org using utorrent, i usually sit on around 800k/b per second, so i'll download a 750mb movie is basically 10mins :blink:
  • 5 months later...
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
