  • Replies 98
Posted Images
Ive tested schools due to a friend that works for the EDU dep. They are getting much faster speeds than your average residential house as you would presuem.
"Telstra Bigpond 8mb ADSL2"
Thats ADSL1.
ADSL2+ is rated to 24mbps, you may experience 8MB but if thats what your net is rated at then its ADSL1.
Telstra lumps its High speed ADSL1 and ADSL2+ plans into "High Speed" so unless you talk to the activations department, you probably didnt choose.
I'm on Westnet 1.5MB.
I was on that until 2 months ago-ish
Changed to AAPT because they offer unlimited downloads between 8pm-8am on the 8Mbps plan.
For us WA geezers it's 5pm-5am
:P Fkn Grouse!
Edited by Topaz
It wont let me try it from work, however when i download at home via bitsoup.org using utorrent, i usually sit on around 800k/b per second, so i'll download a 750mb movie is basically 10mins :blink:
  • 5 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
